[mapserver-users] truetype symbols
Joe Bussell
joe at otsys.com
Fri Oct 11 10:52:19 EDT 2002
Why would this be any different than placing the declaration in the
mapfile where all my other symbols are declared?
On Fri, Oct 11, 2002 at 06:59:37AM -0600, Richard Greenwood wrote:
> At 04:49 PM 10/10/2002 -0700, you wrote:
> >The font file I am attempting to use is one that ESRI released some time
> >ago. Specifically it is ESRITransportationMunicipal.ttf. I believe
> >that it is UNICODE mapped. I tried the constant character 'e' as well
> >as CHARACTER "e". When I load the font file into gfontview I can
> >see that the airplane image that I am hoping to use is encoded as 'e'
> Don't define the symbol in the map file, define it in the symbol file (just
> move the definition from the map file to the symbol file).
> Rich
> >Have I gone wrong somewhere?
> >Cordially,
> >Joe Bussell
> >On Time Systems
> >www.TrafficDodger.com
> >On Thu, Oct 10, 2002 at 04:31:30PM -0500, Steve Lime wrote:
> >> First thing to check is the font itself. Does it have a UNICODE
> >> character mapping?
> >> Steve
> >> Stephen Lime
> >> Data & Applications Manager
> >> Minnesota DNR
> >> 500 Lafayette Road
> >> St. Paul, MN 55155
> >> 651-297-2937
> >> >>> Joe Bussell <joe at otsys.com> 10/10/02 03:36PM >>>
> >> Greetings Listers and Lurkers,
> >> I have just made a first attempt to apply a truetype symbol with
> >> no
> >> success. I have data for airport locations in a group of shapefiles
> >> tied together with a tileIndex. Presently I use a user defined circle
> >> symbol declared as type ELIPSE. I downloaded a ttf font set that
> >> included an airplane image as one of the characters. I believed form
> >> the documentation site that I could use this symbol in my mapfile as
> >> an
> >> R-value for the SYMBOL object in a CLASS object.
> >> I defined my symbol in my mapfile as such:
> >> SYMBOL
> >> NAME "airportIcon"
> >> TYPE TRUETYPE
> >> FONT transport
> >> FILLED true
> >> ANTIALIAS true
> >> CHARACTER "e"
> >> END
> >> In my fontlist file I declare transport to point to the path of the
> >> font
> >> that I downloaded. I verified that the font was available by writing
> >> a
> >> label with it (looked weird, but it did what I wanted). I attempted to
> >> make use of the defined symbol in the following mapfile snippet:
> >> LAYER
> >> NAME pointsOfInterrest
> >> GROUP defaultLayer
> >> TYPE POINT
> >> TILEINDEX td_pi.shp # DATA usa06037______pi
> >> STATUS ON
> >> LABELITEM "NAME"
> >> CLASSITEM "FEATTYP"
> >> MAXSCALE 150000
> >> ... snip ...
> >> CLASS
> >> # airport
> >> EXPRESSION ( ( [FEATTYP] = 7383 ) )
> >> NAME "Airport"
> >> BACKGROUNDCOLOR 255 255 255
> >> COLOR 0 0 0
> >> OUTLINECOLOR 255 0 0
> >> SIZE 20
> >> SYMBOL "airportIcon"
> >> LABEL
> >> ANGLE AUTO
> >> ANTIALIAS TRUE
> >> BUFFER 2
> >> COLOR 0 0 0
> >> WRAP " "
> >> FONT Arial
> >> FORCE TRUE
> >> MAXSIZE 256
> >> MINDISTANCE 10
> >> MINSIZE 4
> >> OFFSET 0 0
> >> PARTIALS TRUE
> >> POSITION lr
> >> SIZE 6
> >> TYPE TRUETYPE
> >> END
> >> END
> >> ... snip ...
> >> END
> >> The feature does not appear, nor does its label. If I replace
> >> "airportIcon" with "circle" I get the results that we currently
> >> display.
> >> Any ideas on how to get ttf symbols to work?
> >> Cordially,
> >> Joe Bussell
> >> On Time Systems
> >Cordially,
> >Joe Bussell
> >On Time Systems
> Richard W. Greenwood, PLS
> (307) 733-0203
> Rich at GreenwoodMap.com
> www.GreenwoodMap.com
Cordially,
Joe Bussell
On Time Systems
