[mapserver-users] Postgis Connection Error
Düster Horst
Horst.Duester at bd.so.ch
Mon Oct 21 09:59:32 EDT 2002
I try to use a subselection in the DATA block to retrieve data from PostGIS
with the following map-file snip:
LAYER
CONNECTIONTYPE POSTGIS
CONNECTION 'PG Connection'
DATA "wkb_geometry from ( select * from liegen where archive=0 ) as
result"
TYPE POLYGON
MapServer 3.6.2 responses with the following error message:
msPOSTGISLayerWhichShapes(): Query error. prep_DB:Error executing POSTGIS
DECLARE statement (0.6 failed - retried 0.5 and it failed too). DECLARE
mycursor BINARY CURSOR FOR SELECT
Nummer::text,asbinary(force_collection(force_2d(wkb_geometry)),'NDR'),OID::t
ext from ( select * from liegen where archive=0 ) as result WHERE
wkb_geometry && setSRID('BOX3D(604311.575758 229285,604974.424242
229815)'::BOX3D, find_srid('','liegenden','wkb_geometry') )
Some discussions dealed with this method an it should work. Perhaps there
was discussed a solution but the mail archive does'n work.
Any hint????
Best regards
Dr. Horst Düster
Leiter
Abteilung SO!GIS Koordination
Rötihof
CH-4500 Solothurn
Tel.: 032 627 25 32
Fax: 032 627 22 14
horst.duester at bd.so.ch <mailto:horst.duester at bd.so.ch>
<http://www.sogis.so.ch/> www.sogis.so.ch
<mailto:mapserver-users at lists.gis.umn.edu>
