AW: [mapserver-users] Problem querying SDE layer
Oliver Wesp
wesp at gdv.com
Wed Oct 23 06:07:40 EDT 2002
Hi Debbie,
all I can say, is that querying an SDE layer is not different from
querying anything else. I have query and itemquery requests working on
SDE-Layers. But I had a hell of a time getting it done. SDE-Support is
declared as alpha on the Website. Not without any reason.
What mapserver-release do you use? We recently made some changes to the
sourcecode regarding SDE-Support and afaik the changes will be reflected
in 3.7. But I can send you our mapsde.c. I don't know if it solves your
problem, but you can give it a shot. A least it solves some problems you
will be facing as soon as you get the query-modes working.
And here's another adice when working with SDE: don't panic.
greetings
Oliver
> -----Ursprüngliche Nachricht-----
> Von: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu] Im Auftrag
> von Debbie Pagurek
> Gesendet: Dienstag, 22. Oktober 2002 15:57
> An: mapserver-users at lists.gis.umn.edu
> Betreff: [mapserver-users] Problem querying SDE layer
> I have an application that is displaying, zooming etc and SDE
> layer and that's all working fine, but whenever I try to
> query I'm getting:
> Content-type: text/html msSDELayerGetShape(): SDE error.
> SE_stream_fetch(): Shape or row not found. (-22)
> Can anyone suggest what might be wrong? Is querying an SDE
> layer with Mapserver different in some way from querying
> anything else (shapefile)?
> Below is my mapfile and template file (test.html)
> Thanks,
> D. Pagurek
> # Start of map file
> NAME META
> SIZE 500 434
> EXTENT -2647393 5656194 2892379 10462762
> UNITS METERS
> IMAGECOLOR 255 255 255
> # Start of web interface definition
> WEB
> TEMPLATE 'meta.html'
> IMAGEPATH '/usr/www/httpd/htdocs/mapdata/tmp/'
> IMAGEURL '/mapdata/tmp/'
> END
> # Start of legend
> LEGEND
> STATUS ON
> OUTLINECOLOR 0 0 0
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE SMALL
> COLOR 0 0 0
> END
> END #LEGEND
> # Start of scalebar
> SCALEBAR
> LABEL
> COLOR 255 0 0
> SIZE tiny
> END #LABEL
> STYLE 1
> SIZE 100 4
> COLOR 153 153 153
> UNITS meters
> INTERVALS 3
> END #SCALEBAR
> # Start of layer definitions
> LAYER
> NAME surveys
> TYPE polygon
> STATUS DEFAULT
> CONNECTIONTYPE sde
> CONNECTION "myserver.gis.agr.ca,esri_sde,ORACLE,meta,mapper"
> DATA "SURVEYINDEX,shape"
> TEMPLATE "test.html"
> CLASSITEM 'STATUS'
> CLASS
> EXPRESSION 'NOT SURVEYED'
> NAME 'Not Surveyed'
> COLOR 153 153 153
> OUTLINECOLOR 0 0 0
> END
> CLASS
> EXPRESSION 'NOT DIGITAL'
> NAME 'Not Digital'
> COLOR 153 0 51
> OUTLINECOLOR 0 0 0
> END
> CLASS
> EXPRESSION 'NOT ONLINE'
> NAME 'Not Online'
> COLOR 255 0 0
> OUTLINECOLOR 0 0 0
> END
> CLASS
> EXPRESSION 'INCOMPLETE'
> NAME 'Incomplete'
> COLOR 255 255 0
> OUTLINECOLOR 0 0 0
> END
> CLASS
> EXPRESSION 'COMPLETE'
> NAME 'Complete'
> COLOR 51 255 0
> OUTLINECOLOR 0 0 0
> END
> CLASS
> EXPRESSION 'WATER'
> NAME 'Water'
> COLOR 0 0 255
> OUTLINECOLOR 0 0 0
> END
> TOLERANCEUNITS METERS
> TOLERANCE 3
> END # LAYER
> END # MAPFILE
> My template file isn't coming up at all, instead I get the
> above error message. But here's what it looks like:
> <html>
> <body>
> <b>SEARCH WINDOW</b>: [imgext]<br>
> <b>QUERY POINT</b>: ([img.x], [img.y]) image coordinates or
> ([mapx], [mapy]) map coordinates<br> <p>
> INDEX_ID=[INDEX_ID]<br>
> STATUS=[STATUS]<br>
> </body>
> </html>
