[mapserver-users] width of line features
Martin, Daniel
DMartin at erac.com
Thu Oct 24 19:09:47 EDT 2002
If this goes in the docs, I would suggest a highly related answer to the
often asked question "How do I outline these lines?" come right after it:
CLASS
NAME "Streets"
COLOR 0 0 0
SYMBOL 'circle'
SIZE 4
OVERLAYSYMBOL 'circle'
OVERLAYCOLOR 244 0 0
OVERLAYSIZE 2
END
-Dan
> -----Original Message-----
> From: Thomas, Cord [mailto:cthomas at rand.org]
> Sent: Thursday, October 24, 2002 3:50 PM
> To: 'mapserver-users at lists.gis.umn.edu'
> Subject: RE: [mapserver-users] width of line features
> On that issue - can someone, steve, someone, explain the
> reasoning for that
> - also, please put this in the docs - as an example maybe with an
> explanation - very useful information.
> From: Martin, Daniel [mailto:DMartin at erac.com]
> Sent: Thursday, October 24, 2002 11:29 AM
> To: Rob Holloway; mapserver-users at lists.gis.umn.edu
> Size is only half the answer. You need to use a circle
> symbol to be able to
> give the class a size. For example:
> CLASS
> NAME "Interstate Highway - Unseperated"
> COLOR 255 0 0
> SYMBOL 'circle'
> SIZE 5
> END
> It didn't make sense to me at first either, but try it. I promise the
> circle will turn into a thick line.
> -Dan
> > From: Lowell Filak [mailto:lfilak at medinaco.org]
> > Sent: Thursday, October 24, 2002 11:05 AM
> > Subject: Re: [mapserver-users] width of line features
> > You can specify SIZE in the CLASS definition.
> > HTH
> > Lowell F.
> > The following message was sent by Rob Holloway
> > <rholloway_1999 at yahoo.com> on Thu, 24 Oct 2002 06:12:10 -0700 (PDT).
> > > Hi
> > > Is it possible to control the width of line features
> > > (i.e. to make them thicker). I realize this is
> > > probably a simple issue but as the archives seem to
> > > still be down I have no resort but to turn to the
> > > users list. Thanks all!
> > > Rob Holloway
> > > __________________________________________________
> > > Do you Yahoo!?
> > > Y! Web Hosting - Let the expert host your web site
> > > http://webhosting.yahoo.com/
