[mapserver-users] PHP/Mapscript - globally manipulating layer status?
Antti.Roppola at brs.gov.au
Tue Oct 29 20:29:43 EST 2002
Hello all,
When rendering a key, I want to consider map layers
on a case-by-case basis so I can insert text between
key elements.
However, before I can do this I need to set every layer
in the map to "off" before I can switched them on individually:
for($n=0; $n<$num_layers; $n++) {
$layer=$map->getLayer($n);
$layer->set("status",0);
Instead of all this looping, is it possible to globally switch
the status of every layer? Say:
$map->set("layer[]->status",0);
Or even better, apply the same operation to an arbitrary set:
map->set("layer[$selected_layers]->status",1);
Cheers,
Antti
