[mapserver-users] MapServer/MapScript neophite querstion
Daniel Berstein
daniel.berstein at dmapas.com
Wed Oct 30 14:04:59 EST 2002
Hi, I'm brand new to MapServer.
I got MapServer up and running with SHP files in less than 15 minutes. Now
I need a way to integrate information from a MySQL database, which has
"Lat", "Lon", "Text" and "Angle" columns.
Can someone please share a PHP Mapscript code snippet that dynamically
creates a layer, and populates the map image with rows from the above table
(insertion point at "Lat"/"Lon" with text "Text" at angle "Angle"). I would
optimize the query for elements that fit into the current extent. Example:
<?php
$sql = sprintf("SELECT lat, lon, text, angle FROM geodata WHERE lat BETWEEN
%.8f AND %.8f AND lon BETWEEN %.8f AND %.8f", $min_lat, $max_lat, $min_lon,
$max_lon);
$result = mysql_query($sql, $db) or die("Query error");
$map = ms_newMapObj($map_path);
$layer = <what should I put here>
while ($row = mysql_fetch_object($result)) {
<how to draw create queried items>
$image = $map->draw();
$image_url = $image->saveWebImage(MS_PNG,1,1,0);
TIA.
Regards,
Daniel Berstein Z.
Jefe de Proyectos, dmapas.com
Eduardo Hyatt 583, Providencia, Santiago CHILE
*(56) (2) 222 22 60
