[mapserver-users] Fwd: full extent
Rob Holloway
rholloway_1999 at yahoo.com
Thu Sep 5 09:03:17 EDT 2002
Hi
I tried the code you supplied but I'm still having
some problems. The button only works after I have
manually selected my pan radio button - for some
reason the document.mapserv.zoomdir.value = 1;
doesn't seem to work. Have any ideas?
Cheers
Rob
--- Mike Smith <nospam at cnrit.tamu.edu> wrote:
> I borrowed this javascript function from the
> mapserver mail archive and
> it works for me. Just put this code in the head
> block of your HTML page:
> <SCRIPT language=JavaScript>
> function goGlobal() {
> //select the Pan option so we won't zoom in when
> clicking "full extent"
> document.mapserv.zoomdir.value = 1; // NOTE that
> my HTML form is
> named "mapserv"
> document.mapserv.zoomsize.value = 2; // Use your
> form's name here
> after "document."
> //set image extent to the extent value in your map
> file
> // map extent is 33.709580 -4.999999 41.891010
> 5.682579
> document.mapserv.imgext.value = "30.109580
> -4.999999 48.891010 6.082579";
> document.mapserv.imgbox.value = "-1 -1 -1 -1";
> //used with the mapplet
> //set center pixel coordinates - my image size is
> 565 by 670
> document.mapserv.imgxy.value = "232.5 335.0";
> document.mapserv.submit();
> </SCRIPT>
> then call the function from any image (for example)
> using the "onClick"
> action like this:
> <img src="global.jpg" onClick="goGlobal();">
> Hope this helps,
> Mike Smith
> Steve Lime wrote:
> > Subject:
> > full extent
> > From:
> > Rob Holloway <rholloway_1999 at yahoo.com>
> > Date:
> > Wed, 4 Sep 2002 11:14:46 -0700 (PDT)
> > To:
> > mapserver-info at lists.gis.umn.edu
> >Hi
> >I'm trying to create a zoom to full extent button
> >without much success. Does anyone have any
> >suggestions/code to offer. Thanks!
> >Rob
> >__________________________________________________
> >Do You Yahoo!?
> >Yahoo! Finance - Get real-time stock quotes
> >http://finance.yahoo.com
Do You Yahoo!?
