[mapserver-users] How to keep map from zooming/panning when I
refresh?
Puneet Kishor
pkishor at GeoAnalytics.com
Thu Sep 5 13:22:12 EDT 2002
Mike,
Just add a 'redraw' button and on the server side check if the pan/zoom
button exists or not... if it doesn't, don't redo any mapextent
calculations.
pk/
> -----Original Message-----
> From: Mike Smith [mailto:nospam at cnrit.tamu.edu]
> Sent: Thursday, September 05, 2002 10:01 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] How to keep map from zooming/panning when I
> refresh?
> Hello,
> I've got my page working pretty well now thanks to lots of
> Javascript code I borrowed from this mailing list, but I've still got
> one problem that I can't seem to find a solution for in the archives.
> I've got my page set up so that the various layers that are
> available
> to view are in a list on the right-hand side of the page with
> checkboxes
> next to them. And since I wanted the behavior of the page to imitate
> ArcView as much as possible (because most of my users are
> used to that
> interface) I put in a little javascript function that automatically
> reloads the page whenever they check or uncheck a layer
> (without having
> to click a "refresh" button). My problem is that the layer loads or
> unloads fine, but my image also pans or zooms at the same
> time depending
> on what function they have checked. How can I make my page reload
> without changing the current view at all? Even if they have
> the "Zoom
> In" button clicked and the zoomsize is set to "2" I don't
> want the page
> to zoom in when they just add a new layer. Is there a value
> that I can
> set "zoomdir" to besides 1, 0, or -1 that basically disables
> panning and
> zooming altogether?
> Thanks in advance,
> Mike Smith
> P.S. - Here's my javascript code that automatically
> loads/unloads layers:
> function UpdateMap() {
> document.mapserv.submit(); //Note that my form name is "mapserv"
> Then I add this to my checkbox tag:
> onClick="UpdateMap();"
