[mapserver-users] Getting a lat/lon value from a map.
Williams, Chris D.
WILLIC10 at mail.northgrum.com
Thu Sep 5 14:33:06 EDT 2002
I am trying to figure out how to setup my map file with the correct
projection and a way to get lat/lon points from my map using the mapplet
api. I currently have the projection set to the following:
PROJECTION
"proj=latlong"
"ellps=WGS84"
"datum=WGS84"
"no_defs"
END
When I try to print out the CGI variables maplon, maplat, minlat, maxlat, or
any of the others, they are never populated like they aren't defined. What
am I missing in my config or is there a concept here that I am missing?
Thanks
Chris
