[mapserver-users] add nodefaultlib into makefile
Zhang, William
wzhang at c-cor.net
Fri Sep 6 21:01:16 EDT 2002
Michael,
Thank you for the help. After recompiling the freetype.lib (v 2.1.2) with
single-threaded option, I could build gd.lib without error. But that gd.lib
still did not work. So according to the message you wrote on August 29, I
moved back to FreeType v1.3.1. Although I could compiled gd.lib (v 1.8.4)
with FreeType (v 1.3.1), but when using gdtestft.c to test gd.lib,
gdImageStringFT function returned error message: "libgd was not build with
FreeType font support". Do you have some suggestion on this problem?
Thank you again.
William
Here is the build message
Deleting intermediate files and output files for project 'Makefile1 - Win32
Debug'.
--------------------Configuration: Makefile1 - Win32
Debug--------------------
Microsoft (R) Program Maintenance Utility Version 6.00.8168.0
Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
cl -I C:\MapServer\SourceCode\zlib -I
C:\MapServer\SourceCode\pnglib\lpng124 -I
C:\MapServer\SourceCode\JPEG\jpeg6b -I
C:\MapServer\SourceCode\FreeType\freetype-1.3.1\freetype\lib -O
-DHAVE_LIBJPEG -DHAVE_LIBPNG -DHAVE_TTF /c gd.c
Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 12.00.8168 for 80x86
Copyright (C) Microsoft Corp 1984-1998. All rights reserved.
gd.c
-DHAVE_LIBJPEG -DHAVE_LIBPNG -DHAVE_TTF /c gdfontt.c
gdfontt.c
-DHAVE_LIBJPEG -DHAVE_LIBPNG -DHAVE_TTF /c gdfonts.c
gdfonts.c
-DHAVE_LIBJPEG -DHAVE_LIBPNG -DHAVE_TTF /c gdttf.c
gdttf.c
-DHAVE_LIBJPEG -DHAVE_LIBPNG -DHAVE_TTF /c gdft.c
gdft.c
LIB gd.obj gdhelpers.obj gd_gd.obj gd_gd2.obj gd_io.obj gd_io_dp.obj
gd_io_file.obj gd_ss.obj gd_io_ss.obj gd_png.obj gdxpm.obj gdfontt.obj
gdfonts.obj gdfontmb.obj gdfontl.obj gdfontg.obj gdtables.obj gdttf.obj
gdft.obj gdcache.obj gdkanji.obj g
d_jpeg.obj gd_wbmp.obj wbmp.obj libpng.lib zlib.lib libjpeg.lib freetype.lib
Microsoft (R) Library Manager Version 6.00.8168
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
zlib.lib(adler32.obj) : warning LNK4006: _adler32 already defined in
libpng.lib(adler32.obj); second definition ignored
zlib.lib(compress.obj) : warning LNK4006: _compress2 already defined in
libpng.lib(compress.obj); second definition ignored
zlib.lib(zutil.obj) : warning LNK4006: _zcfree already defined in
libpng.lib(zutil.obj); second definition ignored
zlib.lib(zutil.obj) : warning LNK4006: _z_errmsg already defined in
C:\MapServer\SourceCode\FreeType\freetype-1.3.1\freetype\lib pngtogd.c
gd.lib libpng.lib zlib.lib libjpeg.lib
pngtogd.c
Microsoft (R) Incremental Linker Version 6.00.8168
/out:pngtogd.exe
pngtogd.obj
gd.lib
libpng.lib
zlib.lib
libjpeg.lib
C:\MapServer\SourceCode\FreeType\freetype-1.3.1\freetype\lib gdtestttf.c
gdtestttf.c
/out:gdtestttf.exe
gdtestttf.obj
gd.lib
libpng.lib
zlib.lib
libjpeg.lib
C:\MapServer\SourceCode\FreeType\freetype-1.3.1\freetype\lib gdtestft.c
gdtestft.c
/out:gdtestft.exe
gdtestft.obj
gd.lib
libpng.lib
zlib.lib
libjpeg.lib
Makefile1.exe - 0 error(s), 70 warning(s)
