[mapserver-users] (Fwd) [maplab-users] This is a weird one
woodbri at swoodbridge.com
Sat Sep 7 00:59:35 EDT 2002
I sent this to the maplab list, but it might be a mapserver issue.
Steve L, do you have any ideas?
-Steve W.
------- Forwarded message follows -------
I'm not sure if this is a maplab or mapserver issue, but here goes.
This is Linux RH 6.2, MS 3.6.2 from DMS site, maplab-2.0rc3 built as
requested, CGI and with the options per directions. MS is built with
-DIGNORE_MISSING_DATA
I build the vmap0 app that uses uses a tileindex with 4 directories.
I
found out that one of the files CROPA_area.shp was bad because I
couldn't get it to generate an image - The php was generating an
error
in $map->draw(), so I deleted the files once I found out they were
bad.
The strange thing is that the maplab preview then started to work,
the
gmapfactory app still failed to generate an image! So I created an
empty CROPA_area.shp fileset for the two directories that where
missing it and the problem went away.
I know it was that layer because it worked it I toggled it off and
failed when it was on.
So the questions are:
1) Why did I get the error if -DIGNORE_MISSING_DATA is set
2) Why did preview work but not the gmap app
Any ideas on this?
-Steve
Maplab-users mailing list
Maplab-users at dmsolutions.ca
http://lists.dmsolutions.ca/mailman/listinfo/maplab-users
------- End of forwarded message -------
