[mapserver-users] msLoadMap(): Unable to access file.
Joan Waters
Joan.Waters at gov.ab.ca
Mon Sep 9 19:48:15 EDT 2002
Hello MapServer listers;
I recently downloaded and successfully installed the MapServer Itasca demo
(itasca3.5.tar.gz), but have since been unable to get the application going
using my own data. (We're running IIS 5.0 on Windows 2000, and I'm using
the pre-compiled MapServer exe found in ms36gif_wms.zip.) I - naively -
edited the mapfile in the demo data to reflect shapefiles I placed in the
"data" folder, and updated the layer names in the demo_init.html file,
thinking it might work. Alas, no luck. I get the error message:
(c:\inetpub\wwwroot\mapserver\map236.map). Much hacking, template and map
file references in hand, has not helped.
Then I tried constructing a very simple map file, with a very simple
template; still no luck: same message. I know the demo works, so the IIS
permissions etc. should be OK. Can anyone give me a clue why else I might
be receiving this error message? Alternatively, does anyone have a
drop-dead simple set of initialization, map and template files for
displaying one shapefile from which I could start building a working app?
(The on-line tutorial doesn't seem to show all the files needed to construct
a browsable map, just the mapfile listing.) Thanks in advance for any
help.
The template file:
<html>
<head><title>MapServer Map 236 Demo</title></head>
<td valign="top" align=center>
<body bgcolor=#FFFFFF>
<center><h1>MapServer Map 236 Demo</h1></center>
<hr>
<form method=GET action="[program]">
<center>
<table border=0 cellspacing=0 cellpadding=4 bgcolor="#000000">
<tr>
<table cellpadding="0" cellspacing="0" border="0">
<tr><td colspan="2"><INPUT NAME="img" TYPE="image" SRC="[img]" width=600
height=600 border=0></td></tr>
<tr>
<td> <font size=-1 face="arial,helvetica"
color="#FFFFFF"><b>Powered by MapServer</b></font></td>
</tr>
</table>
</td>
The map file:
WEB
TEMPLATE map236.html
END
NAME MAP236
EXTENT 150000 5400000 875000 6650000
SIZE 600 600
SHAPEPATH "data"
LAYER
NAME "MAP236"
DATA geol_py
STATUS ON
TYPE POLYGON
CLASS
COLOR 220 220 220
OUTLINECOLOR 0 0 0
END # end of class object
END # end of layer object
END # end of map file
I'm testing these with the following URL:
http://mywebserver/cgi-bin/mapserv.exe?map=c%3A%5Cinetpub%5Cwwwroot%5Cmapser
ver%5Cmap236.map&layer=geol_py&zoomsize=2&program=%5Ccgi-bin%5Cmapserv.exe&m
ap_web_imagepath=c%3A%5Cinetpub%5Cwwwroot%5Ctmp%5C&map_web_imageurl=%5Ctmp%5
C
Joan Waters, P.Geol.
Alberta Geological Survey, Alberta Energy and Utilities Board
joan.waters at gov.ab.ca
This communication is intended for the use of the recipient to which it is
addressed, and may contain confidential, personal and or privileged
information. Please contact us immediately if you are not the intended
recipient of this communication, and do not copy, distribute, or take action
relying on it. Any communication received in error, or subsequent reply,
should be deleted or destroyed.
