[mapserver-users] php
root
root at shadow.munistgo.cl
Tue Sep 10 17:08:28 EDT 2002
Thanks a lot
I am working now
Patricio
El Mar 10 Sep 2002 12:48, Daniel Lagos escribió:
> Change the path extension_dir to /usr/lib/[php_version] on php.ini and
> restart apache.
> On Tuesday 10 September 2002 09:42 am, you wrote:
> > El Lun 09 Sep 2002 01:01, Vinko Vrsalovic escribió:
> > > On Fri, Sep 06, 2002 at 10:10:03AM -0400, root wrote:
> > > > i installed apache_1.3.26, php_4.1.1 y mapserver_3.6.1.
> > > > PHP was installed as CGI
> > > > MapServer version 3.6.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > > > SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7
> > > > INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > > > I copy php_mapscript.so to /usr/local/lib as nobody user
> > > > but phpinfo say me:
> > > > Warning: Unable to load dynamic library './php_mapscript.so' -
> > > > ./php_mapscript.so: cannot open shared object file: No such file or
> > > > directory in
> > > > /www/htdocs/phpinfo_mapscript.phtml on line 21
> > > > extension_dir ./
> > > > Regex Library System library enabled
> > > > Dynamic Library Support enabled
> > > > Thank in advance
> > > > Patricio
> > > is /usr/local/lib the extensions dir? it's usually something like
> > > /usr/local/lib/php/extensions
> > > in phpinfo is detailed what is the extensions dir.
> > I have installed and working mapserver3.5 like DSO and php_mapscript.so
> > is in /usr/local/lib
> > As say over extension_dir is ./
> > I have tried copy it in /usr/local/lib/php/extensions, but nothing
> > the user for it is nobody
> > I don't know, what i have to do
> > Thanks
> D. Lagos H.
