[mapserver-users] MapServer and WMS question
Tweedy, Scott
sctweedy at NRCan.gc.ca
Thu Sep 12 11:47:41 EDT 2002
I have a question about using MapServer. I have a polygon layer that was
created as a MIF file and converted to a SHP file using FME. When this
process was done FME created a layer of the type PolygonM (representation of
a set of parts (rings). Each part (ring) is a set of points connected by
segments that close back to the first point.). Using MapLab and MapServer
directly on the Internet I've never had a problem displaying this layer.
I've been experimenting with creating a WMS server. When I use the GetMap
request on that layer as part of the command:
http://<myserver>/cgi-bin/mapserv.exe?map=wms.map&VERSION=1.1.0&SERVICE=wms&
REQUEST=GetMap
I get an error saying that only a polygon layer can be created with a
polygon request. If I go back to ArcView and convert the PolygonM to a
simple Polygon the request works fine. Does anyone know anything about
support for PolygonM in OGC? I don't really want to go back and reconvert
all the files.
Thanks in advance,
st
