[mapserver-users] queries
woodbri at swoodbridge.com
Mon Sep 16 11:32:55 EDT 2002
Stefan,
I'm not sure what you are trying to achieve. Here is one layer that
styles different attributes in different ways. Is this what you want?
I your case you could change CLASSITEM CFCC to CLASSITEM group
or CLASSITEM id and change the EXPRESSION statements appropriately.
In theory, you could do all of this dynamically in PHP/Mapscript
without a mapfile if that is what you are asking.
-Steve
LAYER
NAME landmark
TYPE POLYGON
STATUS ON
TILEINDEX "tgrindex"
DATA landmark
# MAXSCALE 1999999
MAXSCALE 800000
CLASSITEM CFCC
CLASS
EXPRESSION /^D10/
NAME "Military"
# Military Installation or Reservation
OUTLINECOLOR -1 -1 -1
COLOR 153 153 102
END
CLASS
EXPRESSION /^D4/
NAME "Education"
# Education and Religious institutions
# includes academy, school, colleg or university
COLOR 198 198 222
END
CLASS
EXPRESSION /^D5/
NAME "Transportation"
# Transportation terminals (airport, airfield, train, bus,
marine)
COLOR 153 153 153
END
CLASS
EXPRESSION /^D6/
NAME "Centers"
# Employment center, shopping or major retail center
# Industrial bldg or park, office Bldg or park
# Amusement Center, Government of other centers
COLOR 153 102 102
END
CLASS
EXPRESSION /^D81/
NAME "Golf Course"
COLOR 206 222 198
END
CLASS
EXPRESSION /^D8[0345]/
NAME "Parks"
# Open Space, National Park, Forests
# or other federal land, State or Local Park or forest
COLOR 174 206 165
END
METADATA
"DESCRIPTION" "Area Landmarks"
"RESULT_FIELDS" "LAND CFCC NAME"
END
HEADER "html/land_header.html"
FOOTER "html/land_footer.html"
TEMPLATE "html/land.html"
TOLERANCE 3
END
On 16 Sep 2002 at 16:22, Stefan Stern wrote:
> Hi,
> Sorry, I missed the spot. ;-)
> The dataset is very long and in order to cover all occurences (each
> single id, each group) I'd had to write one mapfile for each id or one
> layer per id.
> Is there a way to make the mapfile more vital, e.g. by passing a
> parameter that decides which filter or expression to use? e.g. ####
> EXPRESSION "T1" ### could be used with a variable like : ## EXPRESSION
> "$filter" ##
> That's where I thought about letting PHP create a temporary mapfile
> (with substituted filters in the EXPRESSION statement) and pass it to
> mapserver.
> Does anybody se an alternative way?
> Regards,
> Stefan
> woodbri at swoodbridge.com wrote:
> >Stefan,
> >Yes, you can use CLASS EXPRESSIONS and I believe
> >FILTER EXPRESSIONS. Check these out in the MapScript reference.
> >-Steve W.
> >On 16 Sep 2002 at 15:22, Stefan Stern wrote:
> >>Hi all,
> >>I use a dataset of points (.shp) that looks similar to this:
> >>id | group | x_ccord | y_coord
> >>T1 | T | 1234 | 12234
> >>T2 | T | 4321 | 4321
> >>F1 | F | 4566 | 3211
> >>I created a mapfile that displays all points.
> >>Now I want to display just certain points according to "id" or
> >>"group". e.g. "display only T1" or "display all T".
> >>My first idea is to write a temporary mapfile with php on the
> >>harddrive and point mapserver to it.
> >>Is there an other way (implemented) in mapserver? ANd if so, where
> >>can I find some documentation about it?
> >>Regards,
> >>Stefan
