[mapserver-users] Projection Help (Please)
Hankley, Chip
Chip.Hankley at GASAI.Com
Tue Sep 17 16:29:32 EDT 2002
I'm having a heck of a time getting a projected layer to work. Here's the
FGDC projection description, and then my PROJ description. Can anyone see
what's wrong?
Basically, it's just not showing up. The mapfile projection is UTM16
(NAD83). I have a UTM15 layer that is in the mapfile that is re-projecting
fine... so I think it has something to do with this one layers PROJ
definition....
TIA
Chip
Horizontal_Coordinate_System_Definition:
Planar:
Map_Projection:
Map_Projection_Name: Lambert Conformal Conic
Lambert_Conformal_Conic:
Standard_Parallel: 33 0 0.000
Standard_Parallel: 45 0 0.000
Longitude_of_Central_Meridian: -89 30 0.000
Latitude_of_Projection_Origin: 33 0 0.000
False_Easting: 914400.00000 meters
False_Northing: 0.00000
Planar_Coordinate_Information:
Planar_Coordinate_Encoding_Method: coordinate pair
Coordinate_Representation:
Abscissa_Resolution: unknown
Ordinate_Resolution: unknown
Planar_Distance_Units: feet
Geodetic_Model:
Horizontal_Datum_Name: NAD27
Ellipsoid_Name: CLARKE1866
Semi-major_Axis: 6378206.4 meters
Denominator_of_Flattening_Ratio: 294.98
PROJECTION
"proj=lcc"
"lat_1=45.000000000"
"lat_2=33.000000000"
"lat_0=33.000000000"
"lon_0=-89.5000000000"
"x_0=914400.00000"
"y_0=0.000"
"ellps=clrk66"
"datum=NAD27"
"to_meter=0.3048006096"
"no_defs"
END
