[mapserver-users] Raster Projection Problem
Shaik Anwar Hussain
shussain at atsincorp.com
Wed Sep 18 11:17:50 EDT 2002
Hi List,
I am having the problem with my raster image display. Does any one
can help me what is wrong in my projection definetion. When i load this
raster image using ARCMAP its showing in the PA exact place.
These are the Data Frame Coordinate System Values in ARCMAP.
NAD_1927_StatePlane_Pennsylvania_South_FIPS_3702
Lambert_Conformal_Conic
False_Easting: 2000000.000000
False_Northing: 0.000000
Central_Meridian: -77.750000
Standard_Parallel_1: 39.933333
Standard_Parallel_2: 40.966667
Latitude_Of_Origin: 39.333333
GCS_North_American_1927
These are my projection definitions.
Map level projection definition
PROJECTION
"proj=poly"
"ellps=GRS80"
"lon_0=77.75w"
"lat_0=40.925n"
"units=m"
END
Layer definition
LAYER
NAME "I99-07"
TYPE raster
DATA "I99-07.tif"
STATUS default
PROJECTION
"proj=lcc"
"lat_1=39.933333333"
"lat_2=40.800000000"
"lat_0=39.333333333"
"lon_0=-77.750000000"
"x_0=609601.219"
"y_0=0.000"
"ellps=clrk66"
"datum=NAD27"
"to_meter=0.3048006096"
"no_defs"
END
END # LAYER
The Projection definition for the raster layer is Pennsylvania South
NAD27 Feet.
I am using Apache web server, Windows 2000 and
MapServer version 3.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
Thanks for your help.
Anwar
www.atsincorp.com
