[mapserver-users] Mapserver / PostGIS Connection troubles
Dave Blasby
dblasby at refractions.net
Wed Sep 18 11:58:57 EDT 2002
"Lowther, David W" wrote:
> We are getting a, "msPOSTGISLayerOpen(): Query error. Error parsing POSTGIS
> connection information."
You should use the newest version of mappostgis.c since it will give you
much better error reporting.
Is your postmaster running and accepting TCP/IP connections (ie. did you
run it with the -i option)?
I've attached mappostgis.c - replace your copy of mappostgis.c with this
one & recompile & re-install.
dave
Type: application/x-unknown-content-type-cfile
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020918/6f701116/mappostgis.bin
