[mapserver-users] .map
woodbri at swoodbridge.com
Thu Sep 19 21:06:35 EDT 2002
John,
There are a few of ways to look at this problem.
One is think of every shape file as a layer and have a bazillion
layers - this may be the right way, but there may be a better way.
An other way is to think of the data as a smaller number of sets of
common objects where each set represents a layer in the map file.
Let say you have a set of telephone poles and every day another city
or region reports on with their telephone poles in their own shape
file. So now you have to include that new shapefile in the map. Bang!
need another layer - right? ... Wrong!
I have a Tiger/Line Mapserver running. The Tiger data is organized by
counties, about 3300 of them in the US, every county has about 10
different shapefiles, that would make about 33,000 shapefiles, but I
only have 10 layers to define the 10 types of data in the mapfile. If
I added another county and its 10 new shapefiles, I would not need to
add any new layers.
The trick is to make a tileindex for each layer that points to the
the 3300 files that represent a single layer. If I add a new shape
file to the map, I update the tileindex to include a reference to the
new file and I never touch the mapfile. This can easily be automated
with a little scripting. In example above of telephone poles it would
work the same way. You copy the new shape files to the map data
directory and run a utility to add its record to the tileindex.
I hope this makes sense,
-Stephen Woodbridge
http://iMapTools.com
On 19 Sep 2002 at 16:17, John Bennett wrote:
> I'm new to this, therefore a simple question.
> I have a large dataset that is being added to daily, full of
> shapefiles and Gifs. For displaying these files using Mapserver is the
> protocol to update the .map file every time the database is updated
> (one big .map file, I don't think so, too big eh!) or make a new .map
> dynamically for each user depending on their request? Thanks for the
> past help. John
