[mapserver-users] line layer label angle changes
Igor Marinovic
zi at manufacture.co.yu
Fri Sep 20 08:20:38 EDT 2002
I had similar problems with PHP MapScript. Actually, the labels were not
rotated randomly around label point. Every letter was rotated once again for
LABELANGLEITEM. I tried several version of freetype, downgrade the
freetype without success.
The solution is compiling the PHP without ttf support. Actually, this
is mentioned in the PHP MapScript FAQ :)
Hope that this will help to someone.
Thanks,
Igor
On Fri, Sep 20, 2002 at 11:45:35AM +0200, Sandor Csaba wrote:
> Hi All,
> I want to label streets with their names. It works fine on my windows box
> (downloaded binaries: ms36gif_gdal_pg_wms.zip). On a Solaris box (the real
> Internet server, mapserv 3.6.1 CGI, Freetype2, PNG support) the labels are
> randomly rotated around the same label point.
> Anybody had similar problems? Can this be a Freetype1 vs. 2 issue?
> I use the following label definition in the mapfile
> LABEL
> COLOR 0 0 0
> TYPE TRUETYPE
> FONT arial
> SIZE 10
> ANTIALIAS true
> POSITION AUTO
> PARTIALS TRUE
> MINFEATURESIZE 1
> FORCE FALSE
> BUFFER 3
> ANGLE AUTO
> END
> Thanks,
> Csaba
> {Kornyezeti Management es Jog Egyesulet
> {Environmental Management and Law Association
> {www.emla.hu
> {1076 Budapest
> {Garay u. 29-31
> {Hungary
> {Tel/fax: 36-1-3228462, 36-1-3529925
> {Mobil: 06-20-949-1447
