[mapserver-users] Itemquery in unknown area
Matthias Scholz
matthias.scholz at vgem-klostermansfeld.de
Fri Sep 20 10:38:54 EDT 2002
Hi to all,
i use the itemquery mode. If the object who i search in the displayed map, then
the itemquery is successfull. But how can i make an (item)query for an object
who is not in the displayed map? If the object was found in the shapefile, the
new map should then display the object with the same scale as the previous or
scale for view the full object.
Example:
The attributes are: gemarkung, flur, zaehler and nenner <--- this together are
uniqe.
The actual part of my mapfile:
LAYER
NAME flurst_itemquery
TYPE POLYGON
STATUS ON
DATA flurstuecke
FILTER ("[GEMARKUNG]" = "%gemarkung%" AND "[FLUR]" = "%flur%" AND "[ZAEHLER]
" = "%zaehler%" AND "[NENNER]" = "%nenner%")
class
color 255 255 255
outlinecolor 0 0 0
end
TEMPLATE "flurstuecke.html"
TOLERANCE 3
HEADER "flurstuecke_header.html"
FOOTER "flurstuecke_footer.html"
END
Suggestions???
Thanks Matthias Scholz
: Verwaltungsgemeinschaft Klostermansfeld :
: Kirchstr. 1 :
: 06308 Klostermansfeld :
: Telefon: (+49) 034772/800 :
: Telefax: (+49) 034772/80200 :
: eMail: info at vgem-klostermansfeld.de :
: WWW: http://www.vgem-klostermansfeld.de :
Diese eMail wurde mit IMP 3.0 gesendet (http://www.horde.org)
