[mapserver-users] Figuring out pixel size for .wld and raster imags
    stevek at avernus.net
    Fri Sep 20 08:31:22 PDT 2002
Ed,
Hot on the trail here...
Plugging the /direct/ URL in reveals that the image is in fact entirely
white (or blank - I'm not sure how to distinguish the two).
Doing a "properties" on the image from the browser reveals
that is is, like I asked it, 600x600. So it looks like image generation
happens (but not with the view I want) and I may have the URL
munging wrong. The most important thing is of course to get
the image generation happening correctly.
Steve
> That's good info.  You're asking for a 600x600 pixel JPEG output image
> from a 1445x1044 source TIFF, so it's not surprising that they are
> smaller files.  However, that size is VERY small.  Can you look at the
> JPEG files themselves (outside of a browser) and see what they contain?
> If you're getting broken image icons but the files are being created,
> then either the URL isn't correct or the Web browser doesn't have
> access to those files.
> If you can fix that problem, it will be easier to debug the others.
> Can you confirm whether the JPEGs being created are blank or not?
> Thanks.
More information about the MapServer-users
