[mapserver-users] img.x versus map.x
Mike Smith
nospam at cnrit.tamu.edu
Tue Sep 24 13:08:28 EDT 2002
Hello listers,
Sorry to sound like a broken record, but I can't seem to get past
this seemingly elementary problem! I still can't get my image to zoom
or pan to the point of my mouse click...it only zooms in to the center
of the image and panning is totally disabled. Thanks to several of you
for offering suggestions, but nothing has worked so far. I'm right on
the edge of uncovering the problem, but can't seem to figure out where a
certain mapserver CGI variable is coming from...here's what I've got:
when I click on my main image, my page reloads and zoomin occurs, but
only to the center of my image, not to the point that I clicked on. I
see in the URL of my browser that the actual coordinates of my mouse
clicks are showing up, however, unlike the Itasca demo and other working
Mapserver pages I've seen, my mouse click coordinates are showing up in
the following format:
..../cgi-bin/mapserv?map.x=214&map.y=43.....
now if I go into the URL field and change the above "map.x" and "map.y"
to "img.x" and "img.y" respectively, then reload the URL...BOOM! My
image shows up zoomed to the right factor and centered on the point I
had clicked on.
Here's my question: How come I get "map.x" and "map.y" when I click my
image? If these were "img.x" and "img.y" then everything would be
working...why is my mapserv CGI program inserting the wrong CGI variable
names? If I can only get it to insert the mouse coordinates as "img.x"
and "img.y" values, I'll be working just fine!
Thanks in advance for your help!
