[mapserver-users] Pre-defined Zoom In/Zoom Out buttons...
Joe Bussell
joe at otsys.com
Fri Sep 27 13:45:08 EDT 2002
www.TrafficDodger.com has just such a zoom bar. I view it like fliing
at different altitudes. The higher you go, the more area you see and
you see less detail. I use a zoomLevel variable in my javascript. Each
button triggers a call to zoomToLevel with its own arguments. Regular
zoomIn and zoomOut increment and decrement this value. I then determine
the extent based on some function of the zoomLevel and my full scale
range.
Cordially,
Joe Bussell
On Time Systems
On Fri, Sep 27, 2002 at 09:45:06AM -0500, Mike Smith wrote:
> Sorry to bother everyone with this, I know this has been addressed
> before in the archives, but I can't seem to find it when I search them.
> I'm trying to enable a Zoom In/Zoom Out bar along side my map (kinda
> like Mapquest or Yahoo maps) where there are buttons that either zoom
> the user in or out to pre-determined levels. I've got Javascript code
> that zooms in and out ok, but the logic is what's throwing me off. I
> want the bottom button to always be the same view, not zoom them out 15
> times from whatever their present view is.... it should zoom them out 15
> times from full extent. I want "full extent" to be the base and each
> button whether it's a zoom in or out button needs to always zoom them to
> the same factor relative to full extent, not their current view...make
> sense? I know I've seen a Mapserver page before that had this little
> zoom bar that I'm describing, but I can't remember where I saw it.
> Anybody have a web page that does this? Or example code that handles
> the logic of pre-defined absolute zoom levels (as opposed to the
> relative ones that the CGI variable "zoom" sets)?
> Thanks
