[mapserver-users] PostGIS performance
Alexander Pucher
pucher at atlas.gis.univie.ac.at
Mon Sep 30 10:45:10 EDT 2002
this time I want to use the mapserv CGI simlpy to generate a choroplethe
map for me, by sending a predefined mapfile to the mapserv executable
and store the map in a tmp directory.
I want to show 4 classes of unemployment, colored depending on values in
a db-table. The unemployment table is linked to the geometry table on
the fly using FILTER in the mapfile.
To to so, I load the respective layer 4 times from PostGIS, and assign
FILTERs to the them to select the relevant polygons.
Everything works fine, the map is created, only that it takes about 25
sec. :-(
I played around a bit and found out that the repeated CONNECTIONs causes
the delay.
Did I miss something in accessing layers fromPostGIS? With shapefiles, I
would have used class expressions to "divide" the layer into classes,
how can I do this without drawing the same layer over and over again
when using PostGIS? AFAIK, I can't use the class expressions in this
case, because I have to link two tables.
I added the mapfile for corrections ;-)
Regards,
alex
# Start of layer definitions
LAYER
NAME "nut3"
STATUS ON
TYPE POLYGON
DATA "the_geom from nut3"
CONNECTIONTYPE POSTGIS
CONNECTION "user=pucher password=xxx dbname=geodb host=localhost"
METADATA
"DESCRIPTION" "NUTS3 Area polygons"
END
CLASSITEM "nurgcd"
CLASS
NAME "No Data"
COLOR 210 210 210
END
END
LAYER
NAME "nut3"
STATUS ON
TYPE POLYGON
METADATA
END
FILTER "nut3.nurgcd=un3rt.geo and un3rt.unit > 16"
CLASSITEM "nurgcd"
CLASS
NAME "unempl. > 16%"
COLOR 255 0 0
END
END
LAYER
NAME "nut3"
STATUS ON
TYPE POLYGON
METADATA
END
FILTER "nut3.nurgcd=un3rt.geo and un3rt.unit > 10 and un3rt.unit < 16"
CLASSITEM "nurgcd"
CLASS
NAME "unempl. 10-16%"
COLOR 250 100 100
END
END
LAYER
NAME "nut3"
STATUS ON
TYPE POLYGON
METADATA
END
FILTER "nut3.nurgcd=un3rt.geo and un3rt.unit > 5 and un3rt.unit < 10"
CLASSITEM "nurgcd"
CLASS
NAME "unempl. 5-10%"
COLOR 250 200 200
END
END
LAYER
NAME "nut3"
STATUS ON
TYPE POLYGON
METADATA
END
FILTER "nut3.nurgcd=un3rt.geo and un3rt.unit > 0 and un3rt.unit < 5"
CLASSITEM "nurgcd"
CLASS
NAME "unempl. <5%"
COLOR 250 220 220
END
END
LAYER
NAME "nut3lin"
STATUS ON
DATA "the_geom from nut3_arc"
#DESCRIPTION "nut3lin"
TYPE LINE
METADATA
"DESCRIPTION" "NUTS3 boundaries lines"
END
CLASS
#NAME "Nuts3 Gebiete"
COLOR 0 0 0
END
END
END
________________________________________________________
Institut fuer Geographie und Regionalforschung
Universitaet Wien
Kartografie und Geoinformation
Departement of Geography and Regional Research
University of Vienna
Cartography and GIS
Universitaetstr. 7, A-1010 Wien, AUSTRIA
Tel: (+43 1) 4277 48644
Fax: (+43 1) 4277 48649
E-mail: alexander.pucher at univie.ac.at
FTP: ftp://ftp.gis.univie.ac.at
WWW: http://www.gis.univie.ac.at/karto
Atlas of Eastern and Southeastern Europe: http://www.aos.ac.at
M$ is not the answer. M$ is the question!
No is the answer -- Eric Naggum
