[Mapserver-users] Re: Use of shptree
Zamil Murji
Zamil.Murji at divestco.com
Fri Aug 1 16:38:22 EDT 2003
Did some experimentation already.
Seems that I got the fastest times with a depth of 1. I started at 10 and decreased by 1 each time. Still at 1 it was loading the image at the same speed as without any indexes. I'm going to try tiling my data and then adding indexes to my tiled data.
Zamil
-----Original Message-----
From: pkishor_98 [mailto:pkishor at geoanalytics.com]
Sent: Friday, August 01, 2003 2:17 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Re: Use of shptree
--- In mapserver-users at yahoogroups.com, "Zamil Murji"
<Zamil.Murji at d...> wrote:
> Hello list,
> I am using shptree to index my shapefiles. I have a
> funny case. Using shptree on one of my pointfiles
> actually increases the time to load an image by 0.5
> seconds. I have a feeling it has something to do with
> the depth factor. How can I see what depth the index
> is created at?
> This shapefile has 1.6 million point
> shapes. Should the depth be higher or lower than what
> the shptree uses?
You created the shptree index, no? When you created it, you specified
the index. If you didn't, it used the default depth. From shptree
documentation --
shptree
Purpose: Creates a quadtree-based spatial index for a shapefile. The
default tree depth is calculated so that each tree node (quadtree
cell) contains 8 shapes. Do not use the default with point files, a
value between 6 and 10 seems to work ok. Your millage may vary and
you'll need to do some experimenting.
Syntax: shptree [shpfile] {depth}
Do some experimentation with different depths. Hope this helps.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
