[Mapserver-users] Rendering classes - what order does mapserver use?
Stepan Kafka
stepan.kafka at centrum.cz
Mon Aug 4 01:42:27 EDT 2003
I think, the shapes are drawn in the order of records in shapefile/other
source. During process, the corresponding class is set for each record. If
you want to change the order of shapes in shapefile, you may pre-sort
shapefile by sortshp which is part of mapserver distribution.
Stepan Kafka
> -----Pùvodní zpráva-----
> Od: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]za uivatele AMC Story
> Odesláno: 2. srpna 2003 20:54
> Komu: mapserver list
> Pøedmìt: [Mapserver-users] Rendering classes - what order does mapserver
> use?
> Hi there everyone,
> I was just wondering in what order mapserver renders the
> difference classes for
> each layer based on their order in the map file. I was hoping that the
> principle would be the same as for rendering layers, so that if a
> class is at
> the top of several for a particular layer, it would displayed
> behind those
> lower down. This doesn't seem to work though. Can someone let
> me know if I
> can specify the order in which classes are drawn, and how?
> Thanks,
> Ali
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Príchozí zpráva neobsahuje viry.
> Zkontrolováno antivirovým systémem AVG (http://www.grisoft.cz).
> Verze: 6.0.504 / Virová báze: 302 - datum vydání: 24.7.2003
Odchozí zpráva neobsahuje viry.
