[Mapserver-users] Mapserver/Mapscript and MySQL 4
Matthew Smith
matt at kbc.net.au
Mon Aug 4 20:51:46 EDT 2003
Hi All
I have an application where I need to:
* Create a layer from a shapefile
* Create an overlying layer of data from a database query.
I am using MySQL 4.0.x, so MyGIS mentioned in the Wiki is out, although
it would have been the preferred solution.
I guess that means that I'll have to generate everything with Mapscript
instead - no real hardship since I do just about everything else in Perl.
Can anyone point me at an example similar to what I'm trying to achieve
(one layer from a shapefile, one from DBI)?
Is using two layer sources like this a reasonable approach, or should I
just dump all my shapefiles into MySQL? I've considered this but feel
that it could be a little awkward as this version of MySQL does not
appear to have native GIS support - my current data structures can
already hold point data, but my "bottom layer" is all polygons.
I'm running Mapserver 3.6.6, Perl 5.8 on Linux.
TIA for any advice.
Cheers
M
Matthew Smith
Kadina Business Consultancy
South Australia
http://www.kbc.net.au
