[Mapserver-users] Once again: no options found in 'init' file
Bjoern Platzen
bplatzen at sosnetz.de
Tue Aug 5 12:30:26 EDT 2003
Hello List,
by searching through the archives, I saw that this seems to be a common
problem. But I did not find any solution that helped me...
I'm trying to project a lat/lon-WGS84-Layer on Gauss-Kruger-Layers. In
my mapfile it looks like this:
# Start of map file
NAME mgla2
STATUS ON
SIZE 6400 6400
SYMBOLSET symbols/symbols.sym
EXTENT 2523000 5680000 2539000 5663000
UNITS METERS
SHAPEPATH "gis_data"
FONTSET /usr/local/httpd/htdocs/parkinfoneuss/font/font.list
IMAGECOLOR 255 250 238
IMAGETYPE png
# Start of web interface definition
WEB
TEMPLATE rahmen.html
MINSCALE 3500
MAXSCALE 200000
IMAGEPATH "/usr/local/httpd/htdocs/parkinfo/tmp/"
IMAGEURL "tmp/"
LOG "/usr/local/httpd/htdocs/parkinfo/mg.log"
error "http://moers.office.sos/parkinfo/error.htm"
END
PROJECTION
"init=epsg:31466"
END
LAYER
NAME bebauung_de012w
TYPE Polygon
STATUS on
DATA bebauung_de012w
CLASS
COLOR 255 165 165
OUTLINECOLOR -1 -1 -1
END # CLASS
END # LAYER
LAYER
NAME industrie_de012w
TYPE Polygon
STATUS on
DATA industrie_de012w
CLASS
COLOR 165 165 165
END # CLASS
END # LAYER
#...some more layers...
LAYER
NAME 'oe'#this is a lat/long-Layer
TYPE Polygon
STATUS on
DATA oeffentl_einr_de012w
CLASS
COLOR 205 44 65
END#CLASS
PROJECTION
"init=epsg:4326"
END#projection
END#Layer
END
#End of mapfile
Now I get the Error
msProcessProjection(): Projection library error. no options found in
'init' file
I tried as well
platzen at codefabrik:~/parkinfo/mg/karte> proj -v +init=epsg:31466
#Transverse Mercator
# Cyl, Sph&Ell
# +init=epsg:31466 +proj=tmerc +lat_0=0 +lon_0=6 +k=1.000000
+x_0=2500000
# +y_0=0 +ellps=bessel +units=m +no_defs
-> epsg:31466 seems to work
and
platzen at codefabrik:~/parkinfo/mg/karte> proj -v +init=epsg:4326
Rel. 4.4.7, 31 March 2003
<proj>:
+proj=latlong unsuitable for use with proj program.
program abnormally terminated
-> epsg:4326 does _not_ seem to work
Then I checked my epsg-file unter /usr/local/share/proj/ and i found
# WGS 84
<4326> +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs no_defs <>
So I think, the error comes because of epsg:4326 but I have no idea, why
it comes and how to workaround...
Any help would be _very_ appreciated...
thanks,
Bjoern.
small office solutions
info at sosnetz.de - http://www.sosnetz.de
