[Mapserver-users] slightly ot: help with cs2cs syntax
Dan Harris
coronadh at coronasolutions.com
Wed Aug 6 14:46:28 EDT 2003
I'm trying to figure out how to convert various state plane coordinates
into long/lat. From what I can tell, other than moving to postgis, the
only way I can do it ( and store the converted points ) is to call cs2cs
from an app.
The problem I'm running into is that the coordinates returned to me are
WAY off.. I must be doing something wrong but documentation examples are
very scarce. So as a test, I'm trying to convert a simple state plane
into long/lat using the following:
cs2cs +init=nad27:502 +to +proj=longlat -r -f "%.2f" << EOF
> 2180318 686562
> EOF
-104.30 57.11 0.00
The resulting latitude is nearly 20 degrees north of where it should be..
To make things even more interesting, if I take off the ending '8' from
2180318, I get this:
> 218031 686562
> EOF
-104.60 39.79 0.00
I have no explanation why taking off the trailing non-decimal number
from the X coord ( which should be completely invalid ) would give me
closer results?
This is closer, but still not accurate in comparisons with MapInfo.
MapInfo says it should be a -104.85, 39.71
Any ideas what I might be doing wrong here? I'm sure the original
coordinates are NAD27, Colorado Central.
Thank you!
-Dan
