[Mapserver-users] qstring - multiple values
Fawcett, David
David.Fawcett at state.mn.us
Wed Aug 6 18:06:44 EDT 2003
I started a page on the Wiki for MapServer Expression documentation and examples.
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapServerExpressions
I added the below example, please add your own and feel free to correct anything that I have written.
David.
David Fawcett
MN Office of Environmental Assistance
> From: Fawcett, David
> Sent: Wednesday, August 06, 2003 3:10 PM
> To: matt at kbc.net.au; mapserver-users at lists.gis.umn.edu; 'Steve Lime'
> Subject: RE: [Mapserver-users] qstring - multiple values
> I figured out the syntax for the expression. Here is an example that works for me:
> The relevant parts of the URL are ...mode=itemnquery&qlayer=basemap&qstring=('[FIPS]'+IN+'27001,27003,27005')
> This is an example where I wanted to select records with a value of 27001, 27003, or 27005 in the FIPS field. (string type field)
> You can see that I also was able to omit qitem=FIPS from the URL because it is contained in the expression in the qstring. (It works with it there too, but I assume that it is ignored)
> Thanks for the help Steve!
> David.
> David Fawcett
> From: Steve Lime[SMTP:steve.lime at dnr.state.mn.us]
> Sent: Wednesday, August 06, 2003 10:38 AM
> Subject: Re: [Mapserver-users] qstring - multiple values
> Remember that qstring is a valid MapServer expression so it's more
> powerful than before, although with that power comes a bit of complexity
> and even cumbersomeness. You're not just limited to string matches. So,
> to do multiple matches you would craft a logical expression like ([item]
> in ('27001','27003',...)). I'm not sure if the in syntax is correct but
> you get the idea. If there is enough interest we could look into
> supporting expressions like:
> EXPRESSION [27001,27003,...]
> and having MapServer recognize that as a list to be matched against a
> single ITEM. Sort of a shortcut logical expression. It would be
> implemented as a new expression type within the software. Thoughts?
> Steve
