[Mapserver-users] Mapped network drive as image source
Howard Mark
MHoward at spaceimaging.com
Thu Aug 7 15:12:27 EDT 2003
I'm using an image index shapefile for a raster layer.
Images display when the "location" is local. e.g. c:\images\image1.jpg
When I use a mapped drive, I get no images.
Is this a problem with IIS not being able to access a mapped drive?
It doesn't work with \\servername\images\image1.jpg syntax either.
TIA for any info!
Mark
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
