FW: [Mapserver-users] Need Info and Help for a first test
    Gregory S. Williamson
    gsw at globexplorer.com
    Fri Aug  8 02:55:44 PDT 2003
Harato --
It is best if you can ask the whole list ... you've exceeded my knowledge (easy to do) so I've cc'ed the list with your question.
Sorry I can't be of more help but I am also a beginner.
Greg W.
-----Original Message-----
Sent:	Fri 8/8/2003 2:33 AM
To:	Gregory S. Williamson
Cc:
Subject:	RE: [Mapserver-users] Need Info and Help for a first test
Thanks for help.
Actually i can't use Arcview so i've used shpinfo and
the only information i've :
File Bounds: (148280, 2267320) (272830, 2370725)
i think
minX=148280 minY=2267320 maxX=272830 maxY=2370725
and unit=DD
but nothing is displayed.
Do you now projection is really necessary ?
how i can have ?
--- "Gregory S. Williamson" <gsw at globexplorer.com>
wrote:
> The shapefile is probably for an area other than the
> Itasca demo -- you need to specify the EXTENT to
> cover your area.
> This covers the San Francisco area:
> EXTENT 542724.08 4173551.37 557476.48 4187315.33
> This is the Itasca demo:
> EXTENT 388107.634400379 5203120.88405952
> 500896.339019834 5310243.30613897
> I used ArcView to get the extents (I had to tell it
> what projection to use, if I recall correctly, to
> get it to show units other than degrees (lat/long).
> If I try to show my shape files using the Itasca
> extent, nothing shows up.
> It is also useful to specify the "projection" either
> by referring to the "epsg" code (and having the
> NAD/Project directories set up) or spelling it out
> the way the Itasca demo does.
> Hope this helps,
> Greg W.
> From:	harato [mailto:harato_1 at yahoo.com]
> Sent:	Thu 8/7/2003 6:15 AM
> To:	Mapserver-users at lists.gis.umn.edu
> Cc:
> Subject:	[Mapserver-users] Need Info and Help for a
> first test
> [English is not my natural language...]
> (Mapserver 4.0b or MapServer 3.6 under Win98/Win2K)
> Hi All,
> I just want to display a layer and I have 3 files
> (dept.dbf/dept.shp/dept.shx). It's an ESRI file
> (ArcView).
> I've try to display the layer using the demo of
> Itasca
> So I want to know If it's not a problem of OGR
> format
> or what's the problem ?
> Can I display my layer with my shape (Arcview)
> directly using this web interface (and change some
> name...) to display something ?
> MapServer 4.0b or MapServer 3.6 (under Windows) can
> support OGR ? is it an OGR problem ?
> (I'm a total beginner/newbie - My Knowledge of OGR
> is
> really bad !)
> Please help me !
> Harato
> __________________________________
> Do you Yahoo!?
> Yahoo! SiteBuilder - Free, easy-to-use web site
> design software
> http://sitebuilder.yahoo.com
> Mapserver-users mailing list
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
More information about the MapServer-users
