[Mapserver-users] Extent units
Dean Gadoury
gadoury at dmsolutions.ca
Fri Aug 8 09:30:18 EDT 2003
As Ed said, it looks like those are decimal degrees. Try using this as
your extent:
EXTENT -71.53179836 -41.29253644 -71.14854968 -41.04421467
Ed McNierney wrote:
>Mario -
>These data appear to be in decimal degrees, which is fine. Make sure
>you use UNITS DD in your MAP file, and set the EXTENT to use the values
>below.
>I have seen certain builds of shpinfo that run correctly and then crash
>after generating their output. Don't worry about it in this case, as
>you have the data you need.
> - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com / Maps a la carte, Inc.
>73 Princeton Street, Suite 305
>North Chelmsford, MA 01863
>Phone: (978) 251-4242 Fax: (978) 251-1396
>ed at topozone.com
>-----Original Message-----
>From: Mario Servin [mailto:mservin at tecnoaccion.com.ar]
>Sent: Thursday, August 07, 2003 5:31 PM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] Extent units
>Hi,
> I was playing with the demo.map and now I want to use my own
>shapefiles
>but I do not know the EXTENT of my map..... I downloaded shapelib from
>the
>Internet and with shpinfo.exe I get:
>Info for calles.shp
>Polyline(3), 338 Records in file
>File Bounds: ( -71.53179836, -41.29253644)
> ( -71.14854968, -41.04421467)
>Then there is some unknown error . I do not know how to use these values
>as
>I never saw something like this values (GG.GGGGGGG) in .map file. Can
>anybody help me?
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Dean Gadoury
DM Solutions Group
72 Chamberlain Ave. Third Floor
Ottawa, Ontario. K1S 1V9
613 565-5056 ext. 24
www.dmsolutions.ca
