[Mapserver-users] MapServer - is this possible?
Paul Ramsey
pramsey at refractions.net
Mon Aug 11 12:05:03 EDT 2003
Mapserver has some simple joining capability wrt DBF files, but I do not
think anything with a live DBMS. Probably we should be looking at the
generalized problem for all attribute data sources.
In the simple case, you can do up a join using mapscript. It is nasty
code, but basically, you first query the database, figure out which
class each polygon should be in, then write up a class rule for each
polygon to give it the appropriate color. Then render. Ouch. But it
works, for maps with small numbers of polygons.
P.
Geoffrey Rowland wrote:
> I'm new to using MapServer, and have a couple of questions. I have some
> data stored in a MySQL database, state, county, and then a number (which
> is related to the county). Now what I want to do is have MapServer
> display an ArcView shapefile of the United States (county level), and
> then use PHP + MapScript to query the database and then color each
> county based on what the number is in the database. Is that possible?
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
