[Mapserver-users] msProcessProjection(): Projection library error. major axis or radius = 0 or not given
Tom H
tom at ecnow.co.uk
Mon Aug 11 18:13:45 EDT 2003
Hi group,
> > If I comment out "proj=latlong"
> > PROJECTION
> > #"proj=latlong"
> > END
> > it outputs a map, and there is no error.
> Tom,
> You need an ellipsoid definition for the projection definition to
> be valid.
> eg.
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> END
in Section 4 Example 1 - On-the-fly Reprojection at;
http://terrasip.gis.umn.edu/cgi-bin/mapserv35?map=/data/projects/tutorial35/s4/s4ex1.map&layer=water&layer=states&layer=relief&zoom=1
in the tutorial for 3.6 there is a projection block for the MAP;
PROJECTION
"proj=laea"
"ellps=clrk66"
"lat_0=45"
"lon_0=-100"
END
and then subsequent projection blocks for the layers;
PROJECTION
"proj=latlong"
END
where there is no ellipsoid definition for each of the layers.
I downloaded all these tutorial files to my mapserver, which is a binary version 4.0 mapserver
on win2000, and im getting the same "msProcessProjection(): Projection library error.
major axis or radius = 0 or not given" error with the tutorial files.
so was there a default ellipsoid definition for earlier versions of mapserver?
and also;
how do I find out the correct ellipsoid definition for shapefiles and their layers?
Thanks,
T.
