[Mapserver-users] MAXFEATURES and postgis layer
Zamil Murji
Zamil.Murji at divestco.com
Tue Aug 12 13:45:52 EDT 2003
Sorry doesn't work...
Here is my DATA tag in my layer definition:
DATA "the_geom from twell LIMIT 1"
Any thoughts?
It brought back this:
prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT wellid::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from twell LIMIT 1 WHERE the_geom && setSRID('BOX3D(-98.8122689312977 28.0409584082397,-98.8045708396947 28.0517352621723)'::BOX3D, find_srid('','twell LIMIT 1','the_geom') )'
Postgresql reports the error ''
More Help:
Error with POSTGIS data variable. You specified '<check your .map file>'.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (<sub query>) as foo using unique <column name> using SRID=<srid#>'
Make sure you put in the 'using unique <column name>' and 'using SRID=#' clauses in.
For more help, please see http://postgis.refractions.net/documentation.php
Mappostgis.c - version of June 12/2003.
-----Original Message-----
From: David Blasby [mailto:dblasby at refractions.net]
Sent: Tuesday, August 12, 2003 11:17 AM
To: Paul Ramsey; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] MAXFEATURES and postgis layer
Paul Ramsey wrote:
> I am guessing that mappostgis.c is ignoring it. The maplayer.c delegates
> that feature to the implementation, and the mappostgis.c implementation
> says nothing about it. Should be a very easy feature to add.
You can also add a "LIMIT n" clause to the SQL in your DATA statement if
you want the functionality "right now".
dave
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
