[Mapserver-users] saveImage --> save in 4.0
Sean Gillies
sgillies at frii.com
Tue Aug 12 16:00:55 EDT 2003
If output formats are properly defined in your map file (see the
map file reference), you change formats using setImageType().
$map->setImageType('JPEG') # JPEG is a built-in
$map->setImageType('JPEG_TRANSPARENT') # Using a named outputformat
# in your map file
outputformat is documented at
http://mapserver.gis.umn.edu/doc40/mapfile-reference.html#outputformat
cheers,
Sean
On Tuesday, August 12, 2003, at 01:25 PM, Simpson, Andrew wrote:
> Hello,
> I've been upgrading perl mapscripts to 4.0 and found the wiki
> MigrationGuide to be a little confusing.
> After stumbling around in the code I found saveImage() is now save()
> and one can use $map->setImageType('xxx') to change the image type.
> How does one change the transparent and interlace options? I see a
> lot of code dealing with outputFormat, but couldn't get any of the
> functions to work.
> Thanks,
> Drew.
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
