[Mapserver-users] saveImage --> save in 4.0
Sean Gillies
sgillies at frii.com
Tue Aug 12 17:25:56 EDT 2003
On Tuesday, August 12, 2003, at 02:50 PM, Simpson, Andrew wrote:
> Thanks, for the response. That helps clarify the new functionality.
> Is there code to instantiate an outputFormat object and access its
> methods/attributes from code without the use of map files?
Here's an example of how you'd do it in Python (because I don't
remember exactly the syntax for the Perl MapScript constructors).
Just add the necessary $->{} noise to Perlify it. ;)
formatobj = outputFormatObj('GD/PNG') # Driver argument
formatobj.transparent = MS_ON
formatobj.setOption('INTERLACE', 'ON')
mapobj.outputformat = formatobj # That's it
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
