[Mapserver-users] help with ???->draw() mapscript function
    Matt Doggett
    mdoggett at coas.oregonstate.edu
    Wed Aug 13 15:46:05 PDT 2003
Well I just discovered a difference...
  If I use Point->draw() for each of the points individually, the point
Labels will appear in the final map.  But if I use Layer->draw() (where
the Layer contains the point shape objects)  the point labels do NOT
appear.
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Eric
Bridger
Sent: Wednesday, August 13, 2003 10:32 AM
To: mdoggett at coas.oregonstate.edu
Cc: 'Mapserver List'
Subject: RE: [Mapserver-users] help with ???->draw() mapscript function
Matt,
You might be right.  I haven't tried the $layer-addFeature(),
$layer->draw() approach with no point->draw()'s.  But it seems like it
should work.
On Wed, 2003-08-13 at 20:44, Matt Doggett wrote:
> Your reply helps a lot. Thanks.
> I'm still not clear about the difference between the Point->draw() and
> the LayerObj->draw().  In my code, I step through each of my points
and
> add them to the LayerObj using LayerObj->addFeature($shape). Then,
like
> you, I call Point->draw(MapObj,LayerObj,Img,...).  But what is the
> difference between calling Point->draw() for each point as it is added
> to the layer, or calling LayerObj->draw() after all the points have
been
> added to the layer?  It seems to me that once all the points (or
> whatever other objects) are added to the layer, calling
LayerObj->draw()
> would do the trick.
> Matt
> From: Eric Bridger [mailto:eric at gomoos.org]
> Sent: Wednesday, August 13, 2003 9:27 AM
> Cc: Mapserver List
> Subject: Re: [Mapserver-users] help with ???->draw() mapscript
function
> If you use MapObj->prepareImage() you should not use MapObj->draw().
You
> are responsible to do all the drawing using LayerObj->draw(), which
> draws on the image prepared and Point->draw() or Rect->draw() etc.
which
> take both the prepared image and a layerObj.  After you've finished
all
> your drawing you should call MapObj->drawLabelCache($img) to draw the
> labels.
> Typically I loop thru each layerObj, turning it on and calling
> LayerObj->draw().  I make sure to skip any dynamic point layers.
> Then I get the point layer obj and call Point->draw() for each point:
> $point->draw($map, $layerObj, $img, undef, $text);
> Finally I call $MapObj->drawLabelCache($img);
> HTH
> Eric
> On Wed, 2003-08-13 at 19:17, Matt Doggett wrote:
> > Can anyone help me out with the mapscript "draw" function?
> >  From what I see we've got a PointObj->draw(),  LayerObj->draw(),
> > MapObj->draw(), RectObj-draw(), etc. etc.  So which one should I
use?
> > I'm using mapscript to dynamically create a layer containing point
> > observations and I get different results depending on which object
> > function I use.
> > Matt
> > Matt Doggett
> > Spatial Climate Analysis Service
> > Oregon State University
> > 316 Strand Ag Hall
> > Corvallis, OR 97331
> > (541)737-9153
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
