[Mapserver-users] Updating to Maserver 4
Frank Warmerdam
warmerdam at pobox.com
Thu Aug 14 09:59:25 EDT 2003
Steffen Gebhardt wrote:
> Hi to all,
> I try to update to Version 4.0. I downloaded the binaries and additionaly
> freetype 2.0.4; gdal 1.1.9; libgeotiff 1.2.1; postgis 0.7.5; libtiff 3.6.0.
> beta; gd 2.0.12; proj 4.4.7; w3c-libwww 5.4.0
> I'm occuring problems when installing libgeotiff, which says libtiff 3.6.0.
> beta or later is required, which I allready installed succesfully. What to do?
> Another error is occuring by installing gdal.
> make[2]: *** [jpeg2000dataset.o] Error 1
> make[2]: Leaving directory `/tmp/unpacked/gdal-1.1.9/frmts/jpeg2000'
> make[1]: *** [sub-libs] Error 1
> make[1]: Leaving directory `/tmp/unpacked/gdal-1.1.9/frmts'
> make: *** [frmts-target] Error 2
> Where to find the JPEG2000 library?
Steffen,
I don't know why you are getting the above error. GDAL's configure should only
add the jpeg2000 directory to the driver build list if you have the JasPer
library on your system. You might want to try adding "--without-jasper" to
your configure options unless you really want JPEG2000 support.
I would add, it appears you cut off the actual error message from building
jpeg2000dataset.cpp.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
