[Mapserver-users] Problem with Oracle Spatial.
Wilman Rojas
wilmanrojas at geoweb.com.co
Fri Aug 15 21:47:55 EDT 2003
This is a multi-part message in MIME format.
--Boundary_(ID_bFPMy5urDDhBGNdjeG7lzw)
Content-type: text/plain; charset=iso-8859-1
Content-transfer-encoding: 7BIT
Mi problem is the next.
apparently all it works well.
but the image of the map is created in blank and limit of the extent
be good.
any help thanks.
Content-type: text/html; charset=iso-8859-1
Content-transfer-encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C3636E.2AAF74C0">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:HyphenationZone>21</w:HyphenationZone>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
<w:UseFELayout/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:SimSun;
panose-1:2 1 6 0 3 1 1 1 1 1;
mso-font-alt:\5B8B\4F53;
mso-font-charset:134;
mso-generic-font-family:auto;
mso-font-pitch:variable;
mso-font-signature:3 135135232 16 0 262145 0;}
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-signature:553679495 -2147483648 8 0 66047 0;}
@font-face
{font-family:"\@SimSun";
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:SimSun;}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoPlainText, li.MsoPlainText, div.MsoPlainText
{margin:0cm;
font-size:10.0pt;
font-family:"Courier New";
span.EstiloCorreo17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:595.3pt 841.9pt;
margin:70.85pt 3.0cm 70.85pt 3.0cm;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Tabla normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
font-family:"Times New Roman";}
</style>
<![endif]-->
</head>
<body lang=3DES link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:35.4pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span lang=3DEN-US =
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'>Mi problem is the =
next. <o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'><o:p> </o:p></span=
></font></p>
<p class=3DMsoNormal =
style=3D'tab-stops:0cm;mso-layout-grid-align:none;text-autospace:
none'><span class=3DGramE><font size=3D2 color=3Dblack =
face=3DTahoma><span lang=3DEN-US
style=3D'font-size:10.0pt;font-family:Tahoma;color:black;mso-ansi-languag=
e:EN-US'>apparently</span></font></span><font
size=3D2 color=3Dblack face=3DTahoma><span lang=3DEN-US =
font-family:Tahoma;color:black;mso-ansi-language:EN-US'> all it works =
well.<o:p></o:p></span></font></p>
none'><font size=3D2 color=3Dblack face=3DTahoma><span lang=3DEN-US =
style=3D'font-size:
10.0pt;font-family:Tahoma;color:black;mso-ansi-language:EN-US'><span
style=3D'mso-spacerun:yes'>=A0</span><span class=3DGramE>but</span> the =
image of the
map is created in<span style=3D'mso-spacerun:yes'>=A0 </span>blank and =
limit of the
extent be good.<o:p></o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 color=3Dblack face=3DTahoma><span =
lang=3DEN-US
e:EN-US'><span
style=3D'mso-spacerun:yes'>=A0</span></span></font><span =
class=3DSpellE><font size=3D2
color:black'>any</span></font></span><font size=3D2 color=3Dblack =
face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma;color:black'> <span =
class=3DSpellE>help</span>
<span class=3DSpellE>thanks</span>.</span></font><font size=3D2 =
face=3DArial><span
lang=3DEN-US =
style=3D'font-size:10.0pt;font-family:Arial;mso-ansi-language:EN-US'><o:p=
</div>
</body>
</html>
--Boundary_(ID_bFPMy5urDDhBGNdjeG7lzw)--
