[Mapserver-users] problem with crontab to delete old map images
Gerry Creager
gerry.creager at tamu.edu
Mon Aug 18 18:17:20 EDT 2003
As Lowell says, local, or, "system" time.
00 *has* broken things for me; don't know why.
Did you edit it as crontab -e or edit the file itself? If you did an
explicit edit, you have to restart crond.
gerry
Lowell Filak wrote:
> It should use local.
> Your minute entry doesn't need to be 00 simply 0 although I'm not sure
> that 00 should break anything.
> Be sure to check /var/log/cron to see if the entry was run by cron.
> HTH
> Lowell
> The following message was sent by "fx gamoy" <fx.gamoy at mapxplore.com> on
> Mon, 18 Aug 2003 21:08:28 +0100.
>>hello
>>i have added a daily job with crontab -e
>>00 20 * * * find /web/mapimage -name "*.png" -exec rm -f {} \;
>>but nothing occur at 20:00.
>>i use a debian woody package and cron seem to be well started
>>which time cron use? universal? (date -u) or local (date)?
>>thanks for any suggestion
>>fx
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020
FAX: 979.847.8578 Pager: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
