[Mapserver-users] shp2mysql.pl and LINE data - resolved.
Bruce Bushby
bruce.bushby at wol.co.za
Mon Aug 18 18:35:20 EDT 2003
Thanks goes to Lowell who suggested looking at the "evaluation" lines,
further
investigation revealed the error...well in my humble, never seen perl,
opinion :) When
reading LINE data, the $shape->{Shapetype} variable was set to "3" and not
"LINE". Adding
an extra "if... eq 3" in a few places seems to work :) I've pasted my hacked
version for
anybody having similar problems.
Anybody got any pointers regarding CONNECTIONTYPE and CONNECTION options in
the mapfile?
I assume it's something like:
CONNECTIONTYPE "mysql"
CONNECTION "host:database:table:x1:y1:x2:y2 ....hmm looks horrible?
Thanks again!
#!/usr/bin/perl
# Copyright (c) 2003, Attila Csipa, Manufaktura Internet Inzenjering doo
$|=1;
use DBI;
use Shape qw/:all/;
$dbname = "mapserver";
$host = "localhost";
$dbuser = "root";
$dbpass = "";
$mac = 0; # this is not a mac
$ENDIAN = 1; # 0 = big endian - mac, 1 = little endian - intel
# --- do not edit below this line
die "Configure database parameters on the beginning of this script file\n"
if $dbname eq "changeme";
$dbh = DBI->connect("DBI:mysql:$dbname:$host:3306",$dbuser,$dbpass) || die
$DBI::errstr ;
$dbh->{RaiseError} = 1;
die "Usage: shp2mysql shpname\n\nwhere shpname is the name (with path) to
the base name of the shape file (do not include file name extensions !)\n"
unless $ARGV[0];
die "Shapefile $ARGV[0] not found !" unless -f "$ARGV[0].shp";
$shape = new Shape $ARGV[0];
$WKB_POINT = 1;
$WKB_LINESTRING = 2;
$WKB_POLYGON = 3;
$WKB_MULTIPOINT = 4;
$WKB_MULTILINESTRING = 5;
$WKB_MULTIPOLYGON = 6;
$WKB_GEOMETRYCOLLECTION = 7;
sub query
my $sth = $dbh->prepare(shift) or die "DBI error $!";
$sth->execute or die "DBI error $!";
return $sth;
sub rect
my ($x0, $y0, $x1, $y1) = @_;
my $minx = $x0 < $x1 ? $x0 : $x1;
my $maxx = $x0 >= $x1 ? $x0 : $x1;
my $miny = $y0 < $y1 ? $y0 : $y1;
my $maxy = $y0 >= $y1 ? $y0 : $y1;
return ($minx, $miny, $maxx, $maxy);
$dbh->do("CREATE TABLE IF NOT EXISTS GEOMETRY_COLUMNS (
F_TABLE_CATALOG varchar(100) NOT NULL default '',
F_TABLE_SCHEMA varchar(100) NOT NULL default '',
F_TABLE_NAME varchar(100) NOT NULL default '',
F_GEOMETRY_COLUMN varchar(100) NOT NULL default '',
G_TABLE_CATALOG varchar(100) NOT NULL default '',
G_TABLE_SCHEMA varchar(100) NOT NULL default '',
G_TABLE_NAME varchar(100) NOT NULL default '',
STORAGE_TYPE int(11) NOT NULL default '0',
GEOMETRY_TYPE int(11) NOT NULL default '0',
COORD_DIMENSION int(11) NOT NULL default '0',
MAX_PPR int(11) NOT NULL default '0',
SRID int(11) NOT NULL default '0',
PRIMARY KEY
(F_TABLE_CATALOG,F_TABLE_SCHEMA,F_TABLE_NAME,F_GEOMETRY_COLUMN)
) TYPE=MyISAM;");
$dbh->do("CREATE TABLE IF NOT EXISTS SPATIAL_REF_SYS (
AUTH_NAME varchar(255) default NULL,
AUTH_SRID int(11) default NULL,
SRTEXT varchar(255) default NULL,
PRIMARY KEY (SRID)
) TYPE=MyISAM;");
%sqlcreate = ( point => " id int(11) NOT NULL auto_increment,
layer int(11) NOT NULL default '0',
x1 double default NULL,
y1 double default NULL,
x2 double default NULL,
y2 double default NULL,
vertices int(11) NOT NULL default '1',
GID int(11) NOT NULL,
PRIMARY KEY (id),
FOREIGN KEY GID(GID, x1, y1, x2, y2) REFERENCES geometry_point_num (GID),
KEY layer (layer),
KEY turbo (x2,y2,x1,y1)",
arc => " id int(11) NOT NULL auto_increment,
PRIMARY KEY (id),
FOREIGN KEY GID(GID, x1, y1, x2, y2) REFERENCES geometry_arc_num (GID),
KEY layer (layer),
line => " id int(11) NOT NULL auto_increment,
PRIMARY KEY (id),
KEY layer (layer),
3 => " id int(11) NOT NULL auto_increment,
PRIMARY KEY (id),
KEY layer (layer),
polygon => " id int(11) NOT NULL auto_increment,
PRIMARY KEY (id),
FOREIGN KEY GID(GID, x1, y1, x2, y2) REFERENCES geometry_polygon_num
(GID),
KEY layer (layer),
annotation => " id int(11) NOT NULL auto_increment,
angle double default '0.0',
size int not null default '10',
txt VARCHAR(255) NOT NULL default '',
PRIMARY KEY (id),
FOREIGN KEY GID(GID, x1, y1, x2, y2) REFERENCES geometry_annotation_num
(GID),
KEY layer (layer),
num => " GID INTEGER NOT NULL,
ESEQ INTEGER NOT NULL,
ETYPE INTEGER NOT NULL,
X1 double default NULL,
Y1 double default NULL,
X2 double default NULL,
Y2 double default NULL,
CONSTRAINT GID_PK PRIMARY KEY (GID, ESEQ, SEQ),
KEY x (X1,Y1)",
bin => " GID INTEGER NOT NULL,
XMIN double default NULL,
YMIN double default NULL,
XMAX double default NULL,
YMAX double default NULL,
WKB_GEOMETRY BLOB,
KEY (GID),
KEY x (XMIN,YMIN,XMAX,YMAX)"
sub mklayer
my ($sh, $type, $add) = @_;
# print "$sh/$type ($sqlcreate{$type})\n";
$dbh->do("drop table if exists $sh");
$dbh->do("drop table if exists ${sh}_num");
$dbh->do("drop table if exists ${sh}_bin");
$dbh->do("create table if not exists $sh ($sqlcreate{$type} $add)");
$dbh->do("create table if not exists ${sh}_num ($sqlcreate{num})");
$dbh->do("create table if not exists ${sh}_bin ($sqlcreate{bin})");
$dbh->do("delete from GEOMETRY_COLUMNS where F_TABLE_NAME =
".$dbh->quote($sh));
$dbh->do("insert into GEOMETRY_COLUMNS
(F_TABLE_CATALOG,F_TABLE_SCHEMA,F_TABLE_NAME,F_GEOMETRY_COLUMN,G_TABLE_CATAL
OG,G_TABLE_SCHEMA,G_TABLE_NAME,STORAGE_TYPE,GEOMETRY_TYPE,COORD_DIMENSION,MA
X_PPR,SRID)
values ('$dbname', '', ".$dbh->quote($sh).", 'GID', '$dbname', '',
".$dbh->quote("${sh}_bin").", 1, '$gtype{$type}', 2, 2, 0)");
sub wkb
$int = $mac ? "N" : "V";
my ($poly, $end, $wkbt)= (shift, shift, shift);
my $wkb = pack("C$int$int", $end, $WKB_GEOMETRYCOLLECTION, 1);
$wkb .= pack("C$int", $end, $wkbt);
my $nr = shift;
if ($poly){
$wkb .= pack("$int", $nr);
while ($nr -- > 0){
my $pts = shift;
if ($wkbt != $WKB_POINT){
$wkb .= pack("$int", $pts);
$double = "";;
for (my $i=0; $i<$pts; $i++){
$double = pack("dd", shift, shift);
if ($mac){
@o = unpack("CCCCCCCCCCCCCCCC", $double);
$double = pack("CCCCCCCCCCCCCCCC",
$o[7],$o[6],$o[5],$o[4],$o[3],$o[2],$o[1],$o[0],$o[15],$o[14],$o[13],$o[12],
$o[11],$o[10],$o[9],$o[8]);
$wkb .= $double;
return $wkb;
@tmp = split(/\//, $ARGV[0]);
$sh = pop @tmp;
undef $fields;
undef @field;
undef $appendvars;
undef $vars;
#$shape->{FieldTypes} = ['Integer'];
for (@{$shape->{FieldNames}}){
$fields .= ", f_$_ VARCHAR(255) NOT NULL DEFAULT ''";
push @field, "f_$_";
$appendvars .= ", f_$_ ";
$vars++;
if ($shape->{Shapetype} eq POINT){
mklayer($sh , 'point', $fields);
} elsif ($shape->{Shapetype} eq LINE){
mklayer($sh , 'line', $fields);
} elsif ($shape->{Shapetype} eq 3){
} elsif ($shape->{Shapetype} eq ARC){
mklayer($sh , 'arc', $fields);
} elsif ($shape->{Shapetype} eq POLYGON){
mklayer($sh , 'polygon', $fields);
for (0..@{$shape->{Shapes}}-1){
undef $appenddata;
for ($v = 0; $v < $vars; $v++){
$appenddata .= ", ".$dbh->quote(${$shape->{ShapeRecords}}[$_][$v]);
#print $dbh->quote(${$shape->{ShapeRecords}}[$_][$v]);
$vrt=-1;
while (${$shape->{Shapes}}[$_]{Vertices}[++$vrt][0] ne undef){
$gid++;
$feat++;
undef %object;
if ($shape->{Shapetype} eq LINE or $shape->{Shapetype} eq 3){
$object{x0} = ${$shape->{Shapes}}[$_]{Vertices}[$vrt-1][0];
$object{y0} = ${$shape->{Shapes}}[$_]{Vertices}[$vrt-1][1];
$object{x1} = ${$shape->{Shapes}}[$_]{Vertices}[$vrt][0];
$object{y1} = ${$shape->{Shapes}}[$_]{Vertices}[$vrt][1];
next unless $object{x0};
# line
print "-";
$dbh->do("insert into ${sh}_num (GID, ESEQ, SEQ, ETYPE, X1, Y1,
X2, Y2) values ('$gid', 1, 1, 2,
'$object{x0}','$object{y0}','$object{x1}','$object{y1}')");
$string = wkb(0, $ENDIAN, $WKB_LINESTRING, 1, 2,$object{x0},
$object{y0}, $object{x1}, $object{y1});
my $sth = $dbh->prepare("insert into ${sh}_bin (GID, XMIN, YMIN,
XMAX, YMAX, WKB_GEOMETRY) values ('$gid',
'$object{x0}','$object{y0}','$object{x1}','$object{y1}', ? )");
$sth->execute($string);
$sth->finish;
($minx, $miny, $maxx, $maxy) = rect($object{x0}, $object{y0},
$dbh->do("insert into $sh (id, layer, vertices, GID, x1, y1, x2,
y2 $appendvars) values ('$feat', '$layer{$sh}', 1, '$gid', '$minx', '$miny',
'$maxx', '$maxy' $appenddata)") if $vrt eq 0;
# line
print "-";
$sth->finish;
} elsif ($shape->{Shapetype} eq POINT){
$object{x0} = ${$shape->{Shapes}}[$_]{Vertices}[$vrt][0];
$object{y0} = ${$shape->{Shapes}}[$_]{Vertices}[$vrt][1];
# point
print ".";
X2, Y2) values ('$gid', 1, 1, 1, '$object{x0}','$object{y0}','0','0')");
'$object{x0}','$object{y0}','$object{x0}','$object{y0}', ?)");
$sth->execute(wkb(0, $ENDIAN, $WKB_POINT, 1, 1,$object{x0},
$object{y0}));
$sth->finish;
y2 $appendvars) values ('$feat', '$layer{$sh}', 1, '$gid', '$object{x0}',
'$object{y0}', '$object{x0}', '$object{y0}' $appenddata)");
# poly
print "O";
@vertex = @{${$shape->{Shapes}}[$_]{Vertices}};
($minx, $miny, $maxx, $maxy) = rect($vertex[0][0],
$vertex[0][1], $vertex[0][0], $vertex[0][1]);
$eseq=1;
push @vertices, $vertex[0][0], $vertex[0][1];
for ($v = 1; $v<=$#vertex; $v++) {
Y1, X2, Y2) values ('$gid', 1, $v, 3,
'$vertex[$v -1][0]','$vertex[$v -1][1]',
'$vertex[$v][0]','$vertex[$v][1]')");
push @vertices, $vertex[$v][0], $vertex[$v][1];
$maxx = $vertex[$v][0] if ($vertex[$v][0] > $maxx);
$minx = $vertex[$v][0] if ($vertex[$v][0] < $minx);
$maxy = $vertex[$v][1] if ($vertex[$v][1] > $maxy);
$miny = $vertex[$v][1] if ($vertex[$v][1] < $miny);
# $dbh->do("insert into vertex (shape,x,y,z) values
('$shape_id','$vertex[$v][0]','$vertex[$v][1]','0')");
XMAX, YMAX, WKB_GEOMETRY) values ('$gid', '$minx','$miny','$maxx','$maxy',
$sth->execute(wkb(1, $ENDIAN, $WKB_POLYGON, 1, $#vertex+1,
@vertices));
$sth->finish;
undef @vertices;
y2 $appendvars) values ('$feat', '$layer{$sh}', '$#vertex', '$gid', '$minx',
'$miny', '$maxx', '$maxy' $appenddata)") if $vrt eq 0;
$vrt = $#vertex;
print "\n";
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Bruce
Bushby
Sent: Monday, August 18, 2003 5:02 PM
To: MAPSERV MAIL LIST MAPSERVE
Subject: [Mapserver-users] shp2mysql.pl and LINE data.
Greetings,
Has anybody else had problems importing ESRI shapefiles using shp2mysql.pl?
When I run the script against my data set it all works beautifully,
importing
point and polygon layers, however it ignores "line" layers, ie: roads.
shp2mysql.pl is a fantastic tool, unfortunately I don't know perl. Having a
look
it seems to cater for line data:
" .....} elsif ($shape->{Shapetype} eq POLYGON){
} elsif ($shape->{Shapetype} eq POLYGON){...."
..any ideas?
Is there a php script to import ESRI shape files into mysql?
Thanks for the help!
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
