[Mapserver-users] setFilter expression error
Nick Petersen-Bergeron
bergeron at zedxinc.com
Tue Aug 19 08:49:53 EDT 2003
Hmmm....the documentation on the mapserver site still has it using
setFilter. I did try changing the query to your method, but got a syntax
error. If this has changed, does anyone know the proper syntax?
Nick
At 11:07 PM 8/18/2003 +0100, Armin Burger wrote:
>Nick,
>this method has changed in MS 4:
>You don't use any more the setFilter() and put everything into the
>queryByAttributes() function. Should be something like
>$countyLayer->queryByAttributes('NAME','leflore', $mapscript::MS_SINGLE);
>(I believe the query item has to be in upper case for shapefiles and
>without the brackets)
>This way I think you cannot use any longer more than one query item.
>Armin
> > I'm trying to run a queryByAttribute on a layer. I've set up the
>following
> > filter expression:
> > $countyLayer->setFilter("('[Name]' = 'leflore')");
> > searching for the string leflore.
> > I then run the queryByAttributes;
> > $countyLayer->queryByAttributes($map,$mapscript::MS_SINGLE);
> > This produces the following error:
> > Mon Aug 18 16:17:06 2003 - msyyparse(): Expression parser error. parse
>error
> > Mon Aug 18 16:17:06 2003 - msQueryByAttributes(): Search returned no
> > results. No matching record(s) found.
> > However, I can't really see anything wrong with my expression. I'm
>using
> > mapscript 4.0. Any ideas?
> > System Administrator
> > ZedX Inc.
> > 369 Rolling Ridge Drive
> > Bellefonte, PA. 16823
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
ZedX Inc.
