[Mapserver-users] problem with crontab to delete old map images
Lowell Filak
lfilak at medinaco.org
Tue Aug 19 09:38:30 EDT 2003
If the entry "41 22 * * * /bin/date >> /tmp/crondate.log" failed (ie.
there is no /tmp/crondate.log file) what exactly leads you to believe
that cron is working correctly?
Lowell
The following message was sent by "fx gamoy" <fx.gamoy at mapxplore.com> on
Tue, 19 Aug 2003 00:09:45 +0100.
> hello
> thanks for yours sugestions
> all the tests failed
> the cron daemon seem to be ok
> i can 't find any cron log file in order to look for a mystake
> fx
> ----- Original Message -----
> From: Bruce Bushby
> To: fx gamoy
> Sent: Monday, August 18, 2003 9:45 PM
> Subject: RE: [Mapserver-users] problem with crontab to delete old
map > images
> perhaps try single quotes:
> 00 20 * * * 'find /web/mapimage -name "*.png" -exec rm -f {} \;' >>
> /tmp/cronmap.log 2>&1
> failing that, try get a log of what is going on:
> 00 20 * * * find /web/mapimage -name "*.png" -exec rm -f {} \; >> >
> failing that, go back to basics:
> and confirm cron is working.
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu >
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of fx gamoy
> Sent: Monday, August 18, 2003 10:08 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] problem with crontab to delete old map
> images
> hello
> i have added a daily job with crontab -e
> but nothing occur at 20:00.
> i use a debian woody package and cron seem to be well started
> which time cron use? universal? (date -u) or local (date)?
> thanks for any suggestion
> fx
