[Mapserver-users] WMS Layer
    Jeff McKenna
    mckenna at dmsolutions.ca
    Tue Aug 19 07:00:20 PDT 2003
Hey Nicol,
Remove the CLASS object from your WMS layer and it works fine.
Jeff
mapserver at geochem.de wrote:
> Dear list
> could someone please give me hint what i am doing wrong.
> I'am trying to integrate an WMS Layer from DM Solutions for testing
> purpose in my Map File.
> Unfortunately the WMS Server returns only an blank yellow image.
> Here is the Map-File i use:
> MAP
>   EXTENT 2200000 -712631 3072800 3840000
>   SIZE            300 300
>   NAME    WMS-Test_Client
> WEB
>   IMAGEPATH "/home/nicol/public_html/mapserver/tmp/"
>   IMAGEURL "/~nicol/mapserver/tmp/"
>   LOG "/tmp/wmsclient.log"
> END
> PROJECTION
>   "init=epsg:42304"
> END
> Layer
>   Name land_fn
>   TYPE POLYGON
>   STATUS DEFAULT
>   CONNECTIONTYPE WMS
>   CONNECTION "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"
>   METADATA
>    "wms_name" "land_fn"
>    "wms_onlineresource" "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"
>    "wms_server_version"  "1.1.0"
>    "wms_title" "land_fn"
>    "wms_srs"      "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326 AUTO:42001
> AUTO:42002 AUTO:42003 AUTO:42004 AUTO:42005"
>    "wms_formatlist"      "image/gif,image/png,image/jpeg,image/wbmp"
>   END
>   PROJECTION
>     "init=epsg:42304"
>   END
>   CLASS
>     NAME test
>     COLOR 255 255 0
>     OUTLINECOLOR 0 0 0
>   END
> END
> END
> If i do the same with an HTTP-Request the image appears correct:
> http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?REQUEST=getMap&VERSION=1.1.0&LAYERS=land_fn&FORMAT=image/gif&SERVICE=wms&SRS=EPSG:42304&BBOX=-2200000,-712631,3072800,3840000
> What do I have to Change in my Map-File?
> BTW: I activate the Option --enable-debug but i get no entry in the
> apache error_log. What else ist needed to get the debbuging information
> in the log Files?
> /usr/local/apache/cgi-bin/mapserv_40 -v
> MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF
> INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> on a Debian 3.0r1 box
> Thank you very much
> Nicol
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Jeff McKenna
GIS Specialist
DM Solutions Group Inc.
http://www.dmsolutions.ca
More information about the MapServer-users
