[Mapserver-users] Fwd: ecw with MapServer
Steve Lime
steve.lime at dnr.state.mn.us
Tue Aug 19 11:29:00 EDT 2003
Return-path: <robertos at escsolution.it>
Received: from mail.state.mn.us
(state.mn.us [156.99.125.109])
by co5.dnr.state.mn.us; Wed, 30 Jul 2003 05:55:46 -0500
Return-Path: <robertos at escsolution.it>
Received: from fep02-svc.flexmail.it ([212.131.248.101] [212.131.248.101]) by mail.state.mn.us with ESMTP for steve.lime at dnr.state.mn.us; Wed, 30 Jul 2003 05:55:43 -0500
Received: from proxy.dbcaditaly.com ([81.73.252.79])
by fep02-svc.flexmail.it
(InterMail vM.5.01.05.09 201-253-122-126-109-20020611) with ESMTP
id <20030730105542.PCRT1532.fep02-svc.flexmail.it at proxy.dbcaditaly.com>
for <steve.lime at dnr.state.mn.us>; Wed, 30 Jul 2003 12:55:42 +0200
Received: from pcesrsa3 (unknown [192.168.0.114])
by proxy.dbcaditaly.com (Postfix) with SMTP id 8D68F5C3BD
for <steve.lime at dnr.state.mn.us>; Wed, 30 Jul 2003 08:37:15 -0400 (EDT)
Message-Id: <000e01c35689$47769d50$7200a8c0 at pcesrsa3>
From: "roberto santinelli" <robertos at escsolution.it>
To: "Steve Lime" <steve.lime at dnr.state.mn.us>
Subject: ecw with MapServer
Date: Wed, 30 Jul 2003 12:56:50 +0200
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 5.50.4522.1200
X-MimeOLE: Produced By Microsoft MimeOLE V5.50.4522.1200
MIME-Version: 1.0
Content-Type: multipart/alternative;
boundary="----=_NextPart_000_000B_01C3569A.0ABF3000"
Messaggio in formato MIME composto da piy parti.
------=_NextPart_000_000B_01C3569A.0ABF3000
Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: Quoted-Printable
Hi Steve,
hoping in your kind as well usefull help, let me ask you, or better depice=
you a problem using MapServer (this is the 3.6.3 Version with GDAL library=
and ECW format and many other ...).
I would like to render some air photos. The image source is a big tiff tile=
d file.
I converted this in to a 8 bit file and removed any kind of mask (e.g. alph=
a channel).
Pointing to this file (50MB the size) as well as indicated in the following=
LAYER
DATA DtmUmbriaF01_2/hills.tif
NAME hills
STATUS DEFAULT
TYPE RASTER
MINSCALE 45000
END #raster layer
i have the right effect.
Unluckly, after a compression with the plug in ECW Compressor 2.6 (ErMapper=
Software) from this tif file and pointing to this new file ecw=20
LAYER
DATA DtmUmbriaF01_2/hills.ecw
NAME hills
STATUS DEFAULT
TYPE RASTER
MINSCALE 45000
END #raster layer
i have the tipical effect i had with a 24 bit tiff file: a distorsion of th=
e colors and under a given scale, a full black image.
Do you already met with this problem?
Perhaps you have idea about to overcome it?
Thanks in advance=20
Roberto Santinelli
fellow ship at CERN,
assistant research at Nuclear Physics department of Perugia University
R&D coordinator at Consorzio ESC
Content-Type: text/html; charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="MSHTML 5.50.4522.1800" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT face=Arial size=2>Hi Steve,</FONT></DIV>
<DIV><FONT face=Arial size=2></FONT> </DIV>
<DIV><FONT face=Arial size=2> hoping in your kind as well usefull help, let
me ask you, or better depice you a problem using MapServer (this is the 3.6.3
Version with GDAL library and ECW format and many other ...).</FONT></DIV>
<DIV><FONT face=Arial size=2>I would like to render some air photos. The image
source is a big tiff tiled file.</FONT></DIV>
<DIV><FONT face=Arial size=2>I converted this in to a 8 bit file and removed any
kind of mask (e.g. alpha channel).</FONT></DIV>
<DIV><FONT face=Arial size=2>Pointing to this file (50MB the size) as well as
indicated in the following</FONT></DIV>
<DIV><FONT face=Arial size=2>LAYER<BR>DATA DtmUmbriaF01_2/hills.tif</FONT></DIV>
<DIV><FONT face=Arial size=2>NAME hills<BR>STATUS DEFAULT<BR>TYPE
RASTER<BR>MINSCALE 45000<BR>END #raster layer</FONT></DIV>
<DIV><FONT face=Arial size=2>i have the right effect.</FONT></DIV>
<DIV><FONT face=Arial size=2>Unluckly, after a compression with the plug in ECW
Compressor 2.6 (ErMapper Software) from this tif file and pointing to this new
file ecw </FONT></DIV>
<DIV><FONT face=Arial size=2>(</FONT></DIV>
<DIV><FONT face=Arial size=2>LAYER<BR>DATA DtmUmbriaF01_2/hills.ecw<BR>NAME
hills<BR>STATUS DEFAULT<BR>TYPE RASTER<BR>MINSCALE 45000<BR>END #raster
layer</FONT></DIV>
<DIV><FONT face=Arial size=2>)</FONT></DIV>
<DIV><FONT face=Arial size=2>i have the tipical effect i had with a 24 bit tiff
file: a distorsion of the colors and under a given scale, a full
black image.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial size=2>Do you already met with this
problem?</FONT></DIV>
<DIV><FONT face=Arial size=2>Perhaps you have idea about to overcome
it?</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial size=2>Thanks in advance </FONT></DIV>
<DIV><FONT face=Arial size=2>Roberto Santinelli</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=Arial size=2>fellow ship at CERN,</FONT></DIV>
<DIV><FONT face=Arial size=2>assistant research at Nuclear Physics
department </FONT> of Perugia University</DIV>
<DIV><FONT face=Arial size=2>R&D coordinator at Consorzio
ESC</FONT></DIV></BODY></HTML>
------=_NextPart_000_000B_01C3569A.0ABF3000--
