[Mapserver-users] Solaris Compilation problem (was: SunONE chokes on template file)
Martin Weinelt
mweinelt at planiglobe.com
Thu Aug 21 04:53:21 EDT 2003
Dear Steve and list,
sorry for comming back with my Solaris compilation problem, but I traced the
error a bit further hoping for even more help..
Following the Solaris8Build advices in the Wiki I get the mapserv
executable and the usual output if I run './mapserv'
If I run './mapserv QUERY_STRING="map=/mapserver/htdocs/cmd_DD.map"' I get the
segfault (no httpd involved, the template is globally defined in this
map-file). The output looks as expected until the first '[' is to be
processed and a core is dumped. Looking a the core I see:
Program terminated with signal 11, Segmentation Fault.
Reading symbols from /mapserver/local/lib/libgd.so.2...done.
Loaded symbols for /mapserver/local/lib/libgd.so.2
Reading symbols from /usr/platform/SUNW,Sun-Fire-880/lib/libc_psr.so.1...done.
Loaded symbols for /usr/platform/SUNW,Sun-Fire-880/lib/libc_psr.so.1
#0 0xfef33474 in strlen () from /usr/lib/libc.so.1
(gdb) bt
#1 0xfef85798 in _doprnt () from /usr/lib/libc.so.1
#2 0xfef8743c in sprintf () from /usr/lib/libc.so.1
#3 0x21a4c in processLine ()
#4 0x234a8 in msReturnPage ()
#5 0x1bf7c in main ()
(gdb)
To my limited understanding there seems to be a problem between the strlen
/sprintf in usr/lib/libc.so.1 on this platform and the way it is called
from processLine () in mapserv? Please correct me.
Is there anything I can try to help this?
Martin
Martin
Am Mittwoch, 13. August 2003 03:35 schrieben Sie:
> What does the layer definition that it dies on look like? I just found
> and fixed an error in the development version that caused a segfault
> when a layer template was defined without any classes defined. E.g.
> LAYER
> NAME "counties"
> DATA "bdry_counpy2"
> STATUS DEFAULT
> TYPE QUERY
> TEMPLATE "success.html"
> END
> I'm hoping this is the same bug.
> Steve
> >>> Martin Weinelt <mweinelt at planiglobe.com> 08/12/03 11:21 AM >>>
> Hi,
> currently installing a MapServer CGI-based site under Solaris / SunONE
> environment. Trying to - to be honest.
> With the first occurence of an angular bracket in the template file, the
> server inserts a nice 'segemtation fault' into the document and aborts.
> The
> maps are generated, though. Nothing in the error log. Any thoughts,
> anyone?
> Thanks, Martin
