[Mapserver-users] Problems: msQueryByPoint, Premature end of script headers
Bruce Bushby
bruce.bushby at wol.co.za
Thu Aug 21 18:58:39 EDT 2003
well that is a large mapfile to debug, perhaps remove everything and just
call one layer.
I noticed you open a projection object with hashed contents, perhaps hash
both
the PROJECTION and END tags.
The error you're getting is normally associated with HTTPD not receiving a
'content-type' ie mapserver didn't sent the 'header'. Also try use shp2img
on
your mapfile and see what happens.
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Gerry
Creager
Sent: Friday, August 22, 2003 12:10 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Problems: msQueryByPoint, Premature end of
script headers
MS 3.7beta (I'll upgrade asap after the demo next Wed! Really!)
RedHat 9
[root at mesonet ~]# /var/www/cgi-bin/mapserv -v
MapServer version 3.7 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=GD2_RGB INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
Mapfile's attached in case that helps. I'm at a loss...
THanks, Gerry
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020
FAX: 979.847.8578 Pager: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
